Lift weight |
Avigil2001
Topic: Lift weightPosted: 19 Mar 2024 at 8:37pm |
Hey guys I have a 1952 allis chalmers ca it’s a great tractor i did a 3 point conversion on it and works great but was wondering what the lift capacity of the rear cylinders are so i dont put to big of an implement?
DrAllis
Thanks(1)
Posted: 19 Mar 2024 at 9:25pm |
When the front wheels come off the ground, it's too much.
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2604 |
Posted: 20 Mar 2024 at 4:49am |
Jeez Doc I just sprayed my coffee on that one🤭😊
Blue Skies and Tail Winds
Dana |
DrAllis
Posted: 20 Mar 2024 at 6:21am |
That is about as intelligent of answer that can be given with the information provided. The 3-point manufacturer (doubtful) doesn't provide any weight lift ability and the poster doesn't give any info on front weights or front tire fluid added (or not). There is no answer other than what I gave. EDIT: Nebraska Test listed the front wheel weight at 710 pounds. So if you had 710 pounds hanging on the 3 point hitch positioned the same distance to the rear of the rear axle as the front wheels are forward from the rear axle, that would be the balance point.
Edited by DrAllis - 20 Mar 2024 at 6:41am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5235 |
Posted: 20 Mar 2024 at 6:52am |
The problem with almost all of the 3pt conversions is: the implement connection places the implement much further rearward than what a comparable PinHitch or SnapCoupler implement would, thus reducing the lift capacity.
With proper front weight on my wide front CA I can move 1000 pounds around on pallets with my SnapCoupler CarryAll. A 3pt CarryAll would have less capacity. When using any 3pt equipment, have your health insurance paid up as pinched fingers and a sprained back are highly likely. The design of the CA hydraulic system when in the "Lift & Hold" setting only uses the Left cylinder to hold implements when in the "Hold" setting, this causes the Left cylinder to explode (I know this for experience) when overloaded. The Oxnard "Deep Tillage Tools" manual for the CA tells you to Re-route both hydraulic cylinder lines to the same ports of the "Hold Valve" so the both cylinders are used when carrying loads.
