D17 wide front pivot pin
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Topic: D17 wide front pivot pin
    Posted: 27 Oct 2010 at 10:25pm
I am working on the front end of my Series 1 D17 and the hole in the front pivot is worn to the point almost having cut out the top of the hole. What is the best way to repair this?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 7:51am
Take it to a good welding shop have them weld up the hole and retap with a bushing similar to the newer D-17's.  I have one in the same shape as yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 8:54am
Is there something that can be used as "fill" to take up some of the space or is it just better to weld in the worn area? The hole is twice as long as is should be.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:02am
I used some square shaft to take up most of the space. Just used the welder to fill in the gaps. Die grinder made the hole round again.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:50am
a WFE ?
isn't there a bushing in there?  you can buy them new, but if the shaft is also worn, it should either be replaced or built up and re-machined round; not an easy task.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 10:20am
Tracy Martin can supply you with a new machined front pivot pin/shaft to weld on to replace the old one.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 10:31am
Get it repaired!  D17 S/N 2061 had front pivot let go when working ground w/AC SC disc about 1967.   Tractor took a nose dive as front axle let go and came to rest under gas tank.  Younger btrother was driving; no one hurt.  After that, "safety wired" the bolt-on bracket that held pivot, and started to check regularly, especially when driving into the barn over the door footings--you could see and hear if things were still "tight."
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 8:58pm
I took my front axle and casting to the local machine shop.  They fixed both the pin and bushing on my D14.  I got them to make the pin a bit longer too so the weight is spread over more area.
This page was generated in 0.083 seconds.
