WD45 Throttle Friction Blocks
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Throttle Friction Blocks
    Posted: 22 Oct 2023 at 6:46pm
My WD45 won't maintain a steady engine speed. 1/4 throttle or higher and the lever keeps sliding down the quadrant to wide open. The spring behind the quadrant doesn't look to be in the best of shape, and the blocks on the quadrant are probably worn some. Is it possible the quadrant will need replaced as well? It does show some wear on the throttle side as compared to the hydraulic lever. But how much is too much? Thanks
WD45
IH Cub Cadet 149,1650,1250
#2 Cart, IH#2 Tiller
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 7:01pm
Broken counterbalance spring above the right headlite on the bellcrank linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 8:18pm
That spring is still there, possibly weak?
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 9:20pm
If it is there, then your friction block (worn) and the coil spring (probably broken) are the next best assumption as to what is wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 10:46pm
That little spring behind the quadrant is very important. The quadrant can be wore pretty bad as far as the grooves go and not be the problem. A new friction block will out last you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2023 at 2:04am
That's what I figured, just wasn't sure how much the quadrant could be worn. There aren't any grooves worn into it, just smooth. Thanks
WD45
This page was generated in 0.805 seconds.
