170 Hydraulic issue
breedman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Topic: 170 Hydraulic issue
    Posted: 24 Jul 2023 at 11:15pm
I recently purchased a 170 and i'm having an issue with the lift arms settling, it takes about 5 minutes to settle, running or not. Any help would be appreciated, THANKS
175D 170D 170G D17 (2)D15 WD45
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 11:52pm
I'd start by looking at the linkages that go from control valves down to the lower 2 arms on 3 point. These get rusted and don't move freely. On controls you've 3 levers to front and 2 smaller levers behind them, try moving the 2 fully forward and back, mine are ussually fully forward. Make sure all levers & linkages can move freely. I soak all moving points on mine down with penetrant at least yearly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 6:10am
Standing behind the tractor, locate the valve section that operates the 3-point hitch. This valve section is easily identified by the hydraulic lines that connect it to the lift cylinders. On the rear of this valve section is a small "tee" handle on the end of a spool. Take a good sized punch with a 1/2" end on it and smack right on the end of that spool a couple of times with a hammer. Then, take a pliers and tighten it as hard as you can. It will tighten just like a nut on a bolt. If it tightens at all, that may be enough to solve your complaint. The degree of smacking has its limits, so if you break the valve on the tractor, your problem, not mine. A settling 3-point hitch is internal leakage of the hydraulic valve section, not any external linkage problem. If you have oil dripping on the ground, then that is your problem, but you don't say that. DO NOT expect this hitch to hold any kind of load up in the air indefinitely !! Not going to happen !! You also don't say settling with a load or not a load ?? So, what is it ??
Edited by DrAllis - 25 Jul 2023 at 6:12am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 7:50am
Hey breedman, good to see you're still around. Haven't seen you post in a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 8:11pm
I checked all the linkages and they all seem to be moving freely, thanks for your input, much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 8:21pm
DrAllis I do not see any external leakage at all and it settles down without a load on it. I will try your method tomorrow. Thanks for sharing your knowledge.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 3:53pm
There are 2 or 3 pivot points under the console.  If any one of them is seized, it will give problems.  You have to reach them by hand to make sure the all move freely.  Even better to take them off, clean, coat with antiseize and reinstall.  With most of my tractors, the linkages for the traction booster and position control were the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 5:33pm
Lift arms settling have NOTHING to do with any of the Traction Booster or Position Control linkages. Settling lift arms are an internal leak of the lift arms spool valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 9:13pm
So I put a heavy back blade on and after playing around with the linkages and tapping on that T handle a little and raising and lowering the arms for a while I did notice a little leakage out of both of the Hydraulic rams. This ONE SEVENTY is an older gas model and on the bottom of each ram there is a port, (they are not on my 170D or 175D) and that's where it's leaking from. I'm guessing that would be my problem so should I have both cylinders rebuilt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 9:20pm
Should be no leaks.
