Rim painting. |
Post Reply ![]() |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4101 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Jul 2023 at 8:12am |
Yesterday I took the power washer to an old garage we're going to paint next weekend. It was a lot of work and took about three times as long as I had thought it would. When my shoulders got tired and I needed a break I worked on painting the front rims on the D-15. Put the ones that came on the tractor back on so I could do this. The reason I post this is because I learned this trick right here. Wish I could remember who posted it originally to give them credit. Anyway, the bead-breaker I bought awhile back did a great job. Made a couple of pieces out of some light cardboard, worked great! Got one done and the first coat on the other. Will put the second coat on today and maybe get it on the tractor. Since the one that I put on the tractor was already getting soft I put the done one on. Thinking I'll take this to the MIAPA show next month with a 2 bottom plow. Will look better with all white wheels. ![]() ![]() |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3948 |
Yep, I do that using plastic sheeting. Cut a piece to cover the whole tire. Use a utility knife to cut out the center the size of the inner bead diameter then stretch it over the rim. When done I fold it up and store for the next time
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Glad to see you take the time to mask off the tires. Will never understand why some people don't. Looks nice.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5243 |
Thanks for posting that trick! Getting ready to paint my D17 wheels. That should work on the rears also.
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
I have a set of three of these shields commercially made from sheet metal. They are a slide open type affair like a "hand" of playing cards and work well. The three sets cover rim sizes from about 12" to 24.5" truck tire rims. They work great to blast wheels clean and refinish without dismounting the tire(s).
That's All Folks!
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2245 |
Looks good in the right color!
Thanks guys. Just an example of something I learned reading this site and filed away until needed. Sloppy rim painting kind of drives me nuts. Have seen many painted with no masking what-so-ever. Some get it done with minimal over-spray. Others, and I remember one Farmall, though not what model, that the rims looked ok but the tires had about a two inch band of Red paint all the way around. This was at an auction, of course. An update on the D-15; Removed the 'three point ' yesterday. Super easy, and if I ever get something that mounts that way, will be easy to go back on. All of my attachments are snap-coupler so that is how she's going to live at least until something new follows me home!
Post Reply ![]() |
