1940 Allis B starting problem
JudgeguyBob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JudgeguyBob Quote  Post ReplyReply Direct Link To This Post Topic: 1940 Allis B starting problem
    Posted: 10 Jul 2023 at 6:47am
Hi, I am in process of rehabilitating a 1940 Allis Chalmers B. Engine has been rebuilt and back on the tractor, but I'm having trouble getting it to run.
When there is no compression on the engine, spark plugs are out, the engine spins fast and free as it should normally.
When spark plugs are in, and compression builds up and the starter switch is engaged the motor spins very slowly with intermittent hesitations.
Battery is new and fully charged, grounding has been checked and rechecked several times, cables and wiring are new and of correct size and connections checked and rechecked.
One electrical shop replaced the starter switch, which didn't correct the problem. Another shop replaced the solenoid, again without correcting the problem.
Magneto was serviced and tested, and timed with good spark.
Is there something I'm missing, perhaps a mechanical issue? And advice would be appreciated.
Bob
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 7:18am
DO YOU HAVE A VOLT METER HOOKED ON BATTERY TO CHECK VOLTAGE DROP.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 8:44am
slow cranking is common if you have a 6 volt battery..... but it should start if your getting gas and spark.. Picture hand cranking the engine. Dont have to spin fast..
That being said, you need to verify you have SPARK and TIMED correctly... that is the biggest problem when people install a mag... verify that when you roll the engine by HAND CRANK, that you hear the MAG SNAP when the crank is at TDC ( top dead center) by the timing mark on the left side bell housing inside the 1 inch hole... NOT THE FIRE MARK.... Then verify that when the engine comes up with #1 piston to TDC, that it is actually #1 plug that is getting the FIRE... you can put that plug in the spark plug wire and roll slowly over and see that it sparks...... if you have gas in the carb, it should start.
I have 12   v batteries on my  B MAG tractors.. They will start when the motor rolls over 1 revolution when cranking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 8:46am
the FIRE order is 1-2-4-3 ... with 1 at the radiator  (front) of the motor.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 10:38am
I know you said correct size on the cables, but give us a bit more info. 6V or 12?  What gauge cables?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 10:55am
Starter switch?  Solenoid?
Too fancy for a B.  My 6v mag B starts in 1 or 2 revolutions when I pull the starter rod (as God intended).  Wink
Anyhoo, if you have a good voltage supply, I would take apart the starter and clean the commutator and make sure the brushes and bearings are good.  I would also clean and dry-lube the bendix.  If everything checks out (it has to be functional, not perfect) put it all back together and see how it spins.
I'd say something checking and tuning up the plunger...but you've got that high-falutin switch and solenoid.
But in the end, if the carb is right and the mac is strong and timed right, it should start if it makes just a few revolutions.  Can the spark jump 1/4 inch?  It should.
Edited by HoughMade - 10 Jul 2023 at 11:03am
1951 B
This page was generated in 1.473 seconds.
