Tie rods for 200
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Tie rods for 200
    Posted: 09 Jul 2023 at 6:19pm
Been a while since I've been on the forum. I've got a question about the inner tie rod assembly for my 200. I bought one a while back from AGCO and other than it's about an inch shorter than original it works. Now I ordered one for the other side and it shows up with the tube being too big to get it to clamp down even with the factory clamp and an added ubolt. And the nut and threads on the tie rod end is metric. I sent it back to the dealer and they ordered another and got the same thing again. Anyone else run into this? The one I got from AGCO earlier is a little shorter but fits. After markets is even shorter when looking at specs and some look the same as the new AGCO ones with a blue oring holding the rubber boot in place.
Doesn't anyone make one like the original with the length from center of joint to tube end being around 18-1/2"? I may just build my own.
Wink
I am a Russian Bot
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 7:11pm
Lonn, a question on the inner tube being too large, is it possible that it fits their new outer tie rod end?  Maybe dealer parts person could call a warehouse or another dealer that has outer 1/2 in stock and ask its diameter.
 Ya know, Like if AGCO or part Manufacturer have decided to build a heavier tie rod?
 A couple years ago my dealer didn't have tie rods in stock for my 180, so ordered a set from ASAP. They're identical in appearance to the old ones, except not bent, worn & rusty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 7:18pm
What part number did you order. There’s two different sets.
254662 and 254661 are for 50” min tread width
250141 and 250140
Edited by Mikez - 09 Jul 2023 at 7:24pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 8:20pm
Chris, I forgot to mention that I also bought the outer male solid tie rods and the solid male tie rods are exactly like the originals and do not fit that new tube. The dealer parts guy said he was going to call AGCO to see what's going on.
The difference isn't much as far as the inside diameter of the tube but clearly too large to fit the male rods.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 8:21pm
Mike, the 662 and 661 are the ones I got, I think. I'd have to look at the boxes. I got both inner and outer rods.
Edited by Lonn - 09 Jul 2023 at 8:53pm
Wink
I am a Russian Bot
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:08am
I've got a new one that I would sell. It's the female end for a 200 and other models. $20.00 plus the ride. Can bring to Hutch,Widlunds, or Albert City.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:12am
I bought some for my XT. They were sent with a new coarse threaded bolt for the clamp. The coarse threaded bolt would not clamp tight enough to lock the inner and outer tubes together. I do not remember where I got them. I still had the original bolts with the large nut and fine threads so I reused them and it has been OK since then.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:30am
rw, it would be nice to find those large fine threaded burrs.
Lynn. I sent you a pm
Wink
I am a Russian Bot
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 10:34am
Howdy Lonn!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 12:07pm
Hey Lars. Been awhile since I've posted here.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 1:21pm
Sent you a PM.
This page was generated in 1.449 seconds.
