7095
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: 7095
    Posted: 19 Apr 2023 at 11:13am
Did anyone, but me,see the you tube video of the 7095 tractor that the Peterson family put together. It's got the 516 cu.in. engine from an N7 combine. 7000 series tin on an 8050 FWA chassis. Cool piece. I don't know how to link the video.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 11:19am
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 11:42am
Awesome tractor! Great attention to details. Mad skills.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2023 at 11:49pm
Hope it lasts with that big engine!
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:22am
I wish that would’ve been a production tractor. They would’ve had room to grow with the 516, and we all know the troubles of the 426 at high horsepower and RPM.
I really like the look of that 7095. If I ever have an 8000 series, I may to do something similar with the sheet metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:28am
He didn't say WHICH PTO gearing he has with the big 1 3/4" shaft. A 7080/8070 normally has 1,000 RPM at 2550 engine RPM, whereas the 1 3/8" shaft has 1000 RPM at 2300 engine RPM's. The reason that big and heavy 516 cube engine was never used was because of COST. It was kind of an obselete engine design that by today's standards would be 650 to 700 cubic inches, instead of only 516. The 8.3/505 cube C-series Cummins is almost exactly the same physical size and weight as the Allis 426, and has power settings of 300 HP, instead of 240 which was the 426 absolute max HP number.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 4:16pm
Dr.allis, the main big 1000 shaft has the 8070/7080 gear and shaft. The countershaft with clutch pack is still all 8050. Seeing that the 8050 has the same countershaft/clutch pack gears, one would expect the gearing to be whatever the 8070/7080 would be. Correct? Unless there is different gearing further up inside the tractor I'm missing.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 4:24pm
Also Thanks guys for the kind words!!!! MUCH APPRECIATED!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 5:03pm
Tyler, I see by your tag line, the D17 with the 3500 series engine. I had forgotten about that project. Do you still own it and do you have any current pictures of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 5:25pm
That is one BAD looking AC with fat tires. Nice job on fabrication of sheet metal. Hope it stays together for them, that’s a lot of nice work and engineering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 6:36pm
Lynn, yea I still have it. Sitting in the same spot too. Lol. Someday when I have more "play" time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 7:11pm
8050 PTO and 8070 PTO gear ratios should be the same......1020 PTO RPM @ 2300 engine RPM.    7080's were the slow ones with a high idle of 2800 rpm and 1000 PTO rpm @ 2550 eng speed.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 8:42pm
Lots of skill went into making it.
You certainly have a Wisconsin accent.
Based on my experience with a 7580 with 8.3 I’d still be nervous of the drivetrain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 8:44pm
the only work it gets is PTO. Not loading the drive train so I'd think it would be just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 8:45pm
Hahahahaha "Wisconsin Accent" I like that!
I don't plan on pulling anything more than what our other 8000 series do, which is a 21 foot 490 IH disc. So the Only place she is putting the power through is the pto.
Edited by Peterson - 20 Apr 2023 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 10:13pm
Cool video. Thanks for sharing.
For some reason at first glance I see resemblance of like an over grown 6000
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 5:06pm
   Super groovy man!!!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 11:38pm
Great project. I can appreciate the amount of time you have in making all of the brackets. And how did you cut the side hoods so accurately?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 7:03am
Peterson, great 7095 video- thanks for sharing. Appreciate all your effort/knowledge/detail. Engine swap projects are much more than just an adapter plate. That’s only the start. The continuance of numerous necessary obstacles or obvious improvements takes a sincere dedication to finish it. Congratulations, seems you more than finished your project. Hoping your new 7095 allows you decades of enjoyable service.
Edited by AC7060IL - 22 Apr 2023 at 7:19am
