AC7020
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Topic: AC7020
    Posted: 08 Apr 2023 at 6:36pm
  I am going to look at a 7020 with 5500 hrs on the clock.
The owner describes the transmission as a powershift but he
is not sure about it other than that.The tractor hasn't had any
use in several years.
   Is there a way to test the transmission and clutches without
 putting a load on it.If the brakes hold I would normally just
try to stall it to see if the clutchs hold.Will that work well enough?
    If I can find a decent tractor with a cab and 3 pt my D17
Wheatland will be for sale.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 9:38am
Drive it up a very steep hill in a fast gear.
If the trans starts growling....you'll know!
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 11:54am
Good luck, no pun intended as anything that has set the oil seal go bad, etc,, get it cheap!!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 1:48pm
Drive in HIGH range at full throttle and upshift thru each gear one-at-a-time. Each shift will be crisp except 3rd to 4th and it is normally the smooothest. 5th to 6th should hit pretty hard.  Try backing up in HIGH reverse using the inching pedal and it takes considerable engine power to get it to get moving. All normal traits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 8:15pm
  Thanks for the advice.I have never had much to do with the 7000 tractors . A cab is
becoming a necessity however.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 5:09am
Bill I never had much to do with them either, but now I have sheds full of them! Buy them lower time that were cared for and wow they’ll treat you right!
Blue Skies and Tail Winds
                          Dana
This page was generated in 0.049 seconds.
