8000 pto size
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 8000 pto size
    Posted: 03 Apr 2023 at 6:17pm
Hello
When someone says the equipment has large 1000 splin.
What does the 8050 have for 1000 pto.
Sorry I don’t have experience with them. Everything Iv done is 540.
Thanks
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 7:05pm
8050 has the 1-3/8" shaft.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 8:27pm
7080, 7580, 8550, 8070, 4W220, and the 4W305 all had the large 1000. IF, if your tractor has the two speed, reversible PTO, then you will have the small 1000 PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 8:31pm
Others will know better than me, but did some of the 7060’s have the large 1000PTO only?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 8:36pm
No, a 7060 would have small 1000.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 8:52pm
Thank you.
I’m down a brush hog due to accident and neighbor has one I could use with large 1000 spline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 6:55am
It depends a little on what decade we are talking about, but the SAE group decided that anything over 165 pto HP must have the larger 1 3/4" spline PTO shaft.  Same goes for the 540 to 1000 switch. Seems as tho in the 1960's , 1000 RPM was required on anything over 100 pto HP.  But, Farmall kept a dual 540/1000 set-up all the way thru the 80's on most of their larger models.
This page was generated in 0.172 seconds.
