strange noise after stopping. fiat 645b |
Post Reply ![]() |
bjorn tore ![]() Bronze Level ![]() ![]() Joined: 04 Mar 2022 Location: Norway Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Mar 2023 at 11:18am |
I have an Fiat allis 645b wheel loader. I have been refilling some hydraulic oil because it was low on oil and it seemed like i had some air in the system. But after refilling this it seems like the hydraulics works fine now. But after i stop the wheel loader i hear a whistle sound, its sounds like a tire that has a leak. the sound comes from right under the cabin near the hydraulic pump. it disapears again 5 min after stop. Cant see any oil drops either underneath.
Does anybody know what this problem is ?
Edited by bjorn tore - 23 Mar 2023 at 11:19am |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8721 |
Pretty sure it has a compressor/air system for the brakes (both of mine do) so quite likely you're hearing an air leak from that.
Darrel |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88102 |
in addition to what Darrel said... i think the air brakes might bleed off and LOCK when the tractor is OFF... You start the motor and let it build up air pressure to RELEASE the brakes ?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8646 |
My 78 545B has air over hyd brakes. No air-no brakes. Has a drum parking brake on driveshaft with the over center lever. Mine has a dual air tank near the hyd pump with petcock drains as well as a large tank in the rt rear corner. Could be similar. I would pursue air leaks first.
Post Reply ![]() |
