B model won't start
masondan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote masondan Quote  Post ReplyReply Direct Link To This Post Topic: B model won't start
    Posted: 12 Mar 2023 at 1:58pm
I have a 1939 B model, hand crank, it ran two years ago
I just rebuilt the carb, magneto. I have great spark and fuel. Tractor won't start, get a little smoke out of the stack, but won't kick over. I tried towing it with another tractor, still nothing.
Any help would be greatly apprceiated
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 2:09pm
sounds like m 38 B ! LOL! --AND my WD-45! AND my C!  --- I'm about to give up on ac tractors!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 3:53pm
The first thing I would suspect is timing. Assuming the mag is timed right internally, make sure the wires are connected to the cylinders 1-2-4-3.
I could probably give you step-by-step instructions, but this link explains it better than I could.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 4:08pm
since you have spark and fuel, it almost has to be the timing...Check plug wires, check impulse operation , check static timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote masondan Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 5:07pm
Thank you, I don't have a "C" or "A" on the fiber wheel. So I'll try putting the beveled tooth at 12 o clock. That might be the problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 5:51pm
yep.. if your missing the "C", then put the bevel tooth at 12 o'clock... and make sure the outside LUG is in this position and install the cover.
Edited by steve(ill) - 12 Mar 2023 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote masondan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 5:49pm
Got it running today. Thanks for your help, Fellas
This page was generated in 0.383 seconds.
