d17 fenders
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: d17 fenders
    Posted: 12 Oct 2010 at 6:10pm
This is my first restoration project, a D17 series IV.  The fenders are bad.  I've seen some on the internet from Allstates, Restoration supply and Steiner but they look crude and cheap.  What do you suggest?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 8:22pm
best would be to cut out the bad areas and weld in patch panels or find another factory set
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 8:41pm
Don't waste your money on those aftermarket ones. They are pretty bad.
A nice used set will cost you but you will be better off. Keep an eye on ebay.
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 9:04pm
I have a set that have been rebuilt. AS good or better than when new. Primed and ready to paint. 425.00 plus ride 620 439 5638
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 9:05pm
Are the series IV fenders any different from other series other than mounting holes for lights and grab handles? Maybe some holes for the hyd control valve setup. Just thinking one could drill a few holes if that is the only difference. Thanks, Eric
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 9:52pm
Series IV fenders are the same as all other D17s (same as D15 too and maybe D17).  The only difference is the holes for the headlights/grab handle.  Hydraulic valve control does not matter.
This page was generated in 0.920 seconds.
