Synthetic motor oil
mikeyD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Topic: Synthetic motor oil
    Posted: 24 Feb 2023 at 5:30pm
Should I use a synthetic blend oil in my 1947 Allis C?
I heard it could make some leaks show up that were not there before.
Is the oil industry phasing out conventional oil? Seems a bit harder to find than the synthetics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 8:40pm
I’m a big supporter of synthetic oils in newer engines but not in the ole girls we all enjoy. Leaks will develop where they may not have been before or leak worse in areas that were already leaking. My hi horsepower Eagle Talon came from the factory with Mobil 1 synthetic in 1990. When I sold her she was still making 300 hp on a big turbo and tuner through AWD with 300,000 miles on it. It is some good stuff when the engine is engineered for it. Don’t ever switch from synthetic to regular oil, conventional oils do not have the same slippery properties as synthetic. I’ve seen several engines spin the bearings after as few as 500 miles when the owner decided to go to conventional oil because it was cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 9:33pm
AC720Man - Thanks for the reply. I will stick w/conventional.
