Creation of the new 170/180 tractors |
DrAllis
Thanks(1)
Topic: Creation of the new 170/180 tractorsPosted: 08 Jan 2023 at 4:53pm |
Where did these two new models in the summer of 1967 come from?? It wasn't really all that difficult for the engineers to do. The new 54 HP One-Seventy was essentially a series 4 D-17 tractor with hydrostatic power steering (new front support, orbitrol and triple section hyd pump) and new sheet metal. The Perkins diesel engine was new to Allis, but was already a proven product elsewhere. The only part in the driveline that was new, was the axle tube castings connected to the final drives. Much thicker and stronger and were an obvious change to look at them. Right at the start, this tractor was a proven reliable unit at 54 HP. The new 64 HP sized One-Eighty was a bit more of a challenge, but still not too tough to create. From the instrument panel forward to the front axle, the new One-Eighty tractor was basically just a One-Ninety with shorter axle spindles. Everything inside the torque tube and the de-rated diesel engine (and eventual 6-cyl gas engine) was 99% One-Ninety components. Now, from the instrument panel on back (transmission/differential), it was still 100% a One-Ninety tranny and differential, but stuffed inside a brand new transmission/differential housing that externally LOOKS LIKE a One-Seventy, but internally is much different. The truly "new" parts were in the final drive area, as the bull gears/bull pinion gears were a different ratio and were much wider and stronger than the One-Seventy tractor. The wider final drive gears then required a new final drive housing for them to fit inside and the heavier axle tubes to connect them to the rear end housing were then utilized on both new tractor models. The hydraulic valves/console and 3-point hitches were identical between the new 170/180 tractors. The One-Eighty then had to have unique sheet metal and a new higher platform with taller brake/clutch pedals and a new seat suspension and angled track taken from the One-Ninety tractor. Remember, A-C had just come out of the disaster of the One-Ninety transmission/rear end/torque tube gears updates and so all the newer stronger parts were being used in the new One-Eighty tractor. I feel if the One-Ninety series hadn't been plauged with all their needed updates, the One-Eighty would have been a couple years sooner. So, the only thing really brand new was the final drives which allowed them to stay with 28 inch rubber on the back. The One-Eighty driveline had to be much stronger than a One-Seventy, as working weights in the field were usually always 9,000+ lbs, versus 7,000 lbs. So, where did they come from?? Just utilizing existing parts off the shelf with a few new tweaks !!!
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Posted: 08 Jan 2023 at 6:20pm |
Using up stocked inventory/parts is the way to make money. I went to Cornell starting in the fall of ‘71 and Dad bought a new 180Gas. Albeit thirsty it was one hell of an engine. We put 5000 hours on her through bout 1985.
Blue Skies and Tail Winds
Dana |
caledonian
Silver Level Access
Posted: 08 Jan 2023 at 7:10pm |
Our 180 diesel has over 11000 hours on it and the transmission rear end and final drives are all original. Never been apart. Engine has never been overhauled. One extremely tough tractor. Wish we could still buy them new. Always thought it would do more work than most any other completive tractor in that horsepower class.
Jason n
Posted: 08 Jan 2023 at 7:51pm |
I always enjoy these Dr. Allis informative reads!!! Keep them coming.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4989 |
Posted: 08 Jan 2023 at 10:28pm |
I agree Jason , Doctor, you should write an article for The old allis news.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3665 |
Posted: 08 Jan 2023 at 11:06pm |
The selection of the 4.236 and later the 4.248 engines in the perkins units were a different engine than most. The sleeves were press fit and then had to be final honed and finished. Many of the other engines had finished bore press in sleeves. I wonder if Perkins sold these to AC or AC spec'd this engine - or didn't know the difference. Maybe to differentiate between the MF and AC ? Also research shows the 236 to be the stronger of the two as it was turbo'd in some models. I have no history on the purchase of the engine other than cost and AC didn't have a 4 cylinder diesel at the time.
Tom59
Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 161 |
Posted: 09 Jan 2023 at 9:07am |
I have always been intrigued by the AC 170 and the 175 tractors and the Perkins engines in them and learning more about them. When I learned the 170 and 175 tractors had Perkins engines and they were 236 and 248 cubic inch displacement I just thought they were like the same Perkins in Massey Ferguson tractors built during that same time period. I after reading posts on this site they were a different engine, at least that what I understand it to be. It was my understanding a 248 Perkins was different engine in a AC 175 tractor than that same displacement Perkins engine in a MF 275 tractor. Please correct any of this if I wrong.
I enjoy DrAllis story on the development of the 170 and 180. |
DrAllis
Posted: 09 Jan 2023 at 9:21am |
I'm no Perkins expert, but this I know: when Massey used them, most of the time the engine block was used to bolt the front end to. There were no side frames in many cases. The blocks A-C used weren't the same, as the engine wasn't expected to be structural part of the frame. I've never overhauled a Perkins. We just didn't have any of them in our territory.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5206 |
Posted: 09 Jan 2023 at 10:45am |
The perkins are still very similar from a massey to the 170/175, with the exception of the crank flywheel bolt pattern may be different, front cover and accessory drive differences. The injection system is actually the same as certain massey tractors. I am certain no perkins 236/248 has wet sleeves, that part of the engine didn't change when used by various tractor manufacturers. There's lots of small differences for various applications, but the overall design is the same.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35707 |
Posted: 09 Jan 2023 at 11:06am |
Still enjoy my 180, easy on fuel, maintenance is a bit of a bear and has some heavier blowby yet gets it done for me. At one time wished had a D19 or a 200 series as a second but then parts here are becoming problematic with loss of dealer.
tomstractorsandtoys
Posted: 09 Jan 2023 at 6:23pm |
If only they would have had completely independent pto. The 190 should have had it as well. My dad talked about how he hated my grandfathers 190XT on a forage harvester as it was so hard to change gears on the headlands to speed up. It didn't help that dad had a brand new 4020. Tom
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 09 Jan 2023 at 7:14pm |
The Perkins engines used in the MF tractors are the ag version identified by front mounts. The blocks were also structural. Perkins industrial engines have the side front mounts as in my 175 and 715B TLB. The Doc and Tbran have explained the internal differences the same as I was told. The 248 is a 236 bored out and normally not turboed except a small turbo on one MF model. 236's can be turboed with higher boost due to thicker cylinder walls. We also have several JCB telahandlers with 236 turbo engines.
Also have a 100kw genset with 236 T at 134 hp.
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 107 |
Posted: 09 Jan 2023 at 7:41pm |
I feel like the whole PTO debacle is something that had to have really hurt Allis over the years, even to the end with the Fiat 6000's. Sure the power director had some advantages, but nothing like a lever to simply turn the PTO on or off whenever you wanted. |
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
tbran
Posted: 09 Jan 2023 at 10:09pm |
the 6000's had/have a lever to simply turn the PTO on or off whenever you wanted.
Edited by tbran - 09 Jan 2023 at 10:10pm |
orangeman
Posted: 10 Jan 2023 at 9:53am |
Having done a bit of research on the Perkins 4.236 and 4.248 engine as supplied to Allis - Chalmers I asked with their U.S.A. support team Clarke Power Solutions if they would check their archives on a spec. build sheet for both engines as supplied to AC and importantly if they could supply it for purchase.
That said, after several communications with the Clarke Power personnel on the Allis Chalmers Perkins in a 715/816 Allis built Loader - Backhoe they seemed less than eager to offer any insights on specification for either engine. One key to securing the specification build sheet for the Perkins 4.236 and 4.248 is unearthing that detail from Allis Chalmers engine literature , (outsourced engines) or perhaps from someone that is close to Perkins Peterborough operation where the engines were built. Maybe someone from across the pond would be kind enough to offer their insights or close contact with Perkins Engine Design group from the 70's - probably all are pensioners now. See additional information about Perkins Peterborough here: HTH's ~ Orangeman
