Identifying my wd45
Hoss1973 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss1973 Quote  Post ReplyReply Direct Link To This Post Topic: Identifying my wd45
    Posted: 02 Jan 2023 at 3:58pm
I just picked up this WD45 and having a time trying to figure out the year it is. I can't find a data plate. The numbers I've found are cast numbers and one stamped. Any help would be greatly appreciated.
The last picture is AM-3853-10
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 4:18pm
The chassis serial number is stamped into the rear end casting (no data plate) just above the lift arm shaft on the left side on the rear face of the housing. It will say WD-XXXXXX. to be a WD45 the s/n must be WD-146607 or greater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss1973 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 4:26pm
10-4 I'll take a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss1973 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 4:32pm
WD 207288 it is hard to see there is a seat bracket over it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 4:49pm
Late 1954 build.  WD45 made from mid 1953 until late summer 1957.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss1973 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 6:30pm
Cool I appreciate your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 5:55am
45-81751-G goes with chassis 207288 for those who wonder about the year of the engine...should be mid to later in 1954.   Looks like at that time there were 21,000 more gas engines than WD45 tractors, which is understandable, as the engine was being used in several other things in the mid-1950's
Edited by DrAllis - 03 Jan 2023 at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss1973 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 2:45pm
That's great info. Got another question for ya. This tractor is a single front and the size on the tire is 9-10 SL is that the right size?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 9:12am
Hoss, that sounds right buy I'm certainly no expert on SFW machines.
This page was generated in 0.083 seconds.
