Hauling tractors and turbo's
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: Hauling tractors and turbo's
    Posted: 23 Dec 2022 at 12:57pm
I watch you tube some and have noticed that when someone
loads a tractor with a turbo on it that some but not all just hop
in the truck and take off down the road.
My question is shouldn't you close off the exhaust pipe and air intake to
prevent air/wind from blowing through the turbo and turning it without oil
when transporting or am I just ignorant..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 3:00pm
I always stuff a rag in my straight pipe on my XT when I haul it. The air breather pre cleaner reduces air flow to the air box.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 3:25pm
We all ways left them run or plugged the exhaust.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 3:49pm
Where & how is traveling wind going backward THROUGH exhaust turbo??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 4:30pm
More so with like an excavator. Because the exhaust pipe has an angle so the wind blows right down it. And it has just become a common precaution
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 4:57pm
I stuffed an old sock or T shirt down the exhaust every time. Talked to my big project mechanic and he mentioned it depends on how your exhaust is positioned. I’ve since followed his advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 5:39pm
Know what happens when you blow across a pop bottle?  It makes a whistling sound.  Why, air goes down into the bottle, forms a vortex, spins and comes back out.  Now picture a turbo vane, down there.  Vortex spins it (remember, a stack pipe is a helluva lot bigger than that pop bottle top!)  Now, do you want that vane spinning, unlubricated for the duration of your trip?  Even if it's plumbed with this in mind, what's a sock or shop rag worth, vs the price of the turbo?Wink
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 6:29pm
My best friend used to haul equipment for his uncles salvage lot. Anything with an operational engine had the exhaust covered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 6:36pm
Any tow I was on and every haul of a truck with a turbo the exhaust was bagged or taped shut. Worked at a truck line truck towed in and no covers on exhaust, one set of valves in overlap so flow path, turbo spun no oil smoked it. Locked tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 7:49pm
More likely what DAVE said... air blowing across the top enters the turbo and also exhausts thru the muffler also.... just like driving down the road with one window open..
Edited by steve(ill) - 23 Dec 2022 at 7:51pm
Tom59 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 8:55pm
I haul my cab tractor with a turbo on my gooseneck trailer backwards. I don’t have to worry about the turbo spinning and cab doors coming open by accident. I know of two different cab tractors that had a door come unlatch and got rip off.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 9:28pm
Best demonstration ever, was while sitting in a railyard with a spot tamper parked alongside the building.  Little Cummins that was ALWAYS shelling turbos, the shop guys blamed Halsett for the failures.  Prevailing wind blowing off the ocean by that maintenance building basically 24/7, the rain cap would bounce up and down, and while standing beside the manifold, you could hear that turbine whirl.
It doesn't matter which way ANYTHING is pointing, any difference in pressure can cause the turbine to spin, and if there's no oil pressure, the bearings will run dry 'till they die.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 9:45pm
In 1976 AirResearch had some bad turbos. They blamed it on hauling the tractors with uncovered exhausts and thus spinning the turbo w/o oil. We were working in La. with carpenter tractor east of Alexandria.  We pulled the intake hose off the turbo  - put a paint drop on the compressor wheel and drove the unit on a truck at 70 MPH - never got the turbo to spin. We even left the intake hose off - made sure some valves were at overlap and took off the muffler of the 7080. Nere a spin hauling forward or backwards. The amount of air that could go thru an engine is so small in CFM that the air will go around the fins and not spin the spool. The amount of venturi effect on the exhaust is equalled on the intake.  AirResearch had to recant and paid for the turbos.  Having said that we try to cover the exhaust when hauling to prevent customer blame if a turbo fails..
Edited by tbran - 23 Dec 2022 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 4:38am
Like I said, what does a sock or shop rag cost?Wink
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 7:43am
Thanks, just could not fathom enough flow to hurt the bearings.
Had a boat dealer tell me to put the engine in gear for road travel so the prop wouldn't spin. I've watched this on other boats going down the road, if the prop spins, it's very slowly and the amount of air going over it will keep it cool.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 3:49pm
there are tractors and equipment hauled back and forth around here every day i dont hear about turbos going bad ,  poeple  haul tractors  to our shop every day they never have bad turbos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 6:48pm
Back while working at a local tractor dealer in the work/study program during high school, that brand tractor company had only had turbo powered tractors a few years. I'd been around pulling tractors with turbos for 5 years or more at that time. I've been witness to may turbos burned out while being hauled to a pull. At Mechanics class at the regional dealers class one day I mentioned covering the exhaust on turbo tractors when hauling and the instructor about laughed me out of class. I know for a fact it can happen no matter what anyone else thinks, say's or does. I will NEVER transport any non running turbocharged engine without plugging the exhaust and intake if possible. It's your turbo do as you please, however don't whine to me if it happens to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 8:46pm
Mike- it's not the bearings, etc that are in a problem situation with a whirling boat prop... the lower unit of outboards and I/0s, and the V-drive transmissions, are full of oil, and under basically no load, so there's not a really serious problem here... the clutch dogs will get a little more wear, and if they're rattling against the dog faces as you go, they WILL start to chip the facing off and destroy the dogs...
...but the biggest problem is the propshaft seal.  The seal's lip is designed to be submerged and wet, which prevents the rubber from cutting into the shaft.  Spin it dry, and two things will happen-  first, the lip seal will start to burn up, and second, the shaft will develop an abrasion groove.  Run it in the lake for a bit, and your drive lube will weep out, eventually leaving no lubrication.  Especially bad in I/O drives, because the upper gearcase is the first portion to become unlubricated, and cooling in the I/O depends on that level being proper, and oil circulation (flung off the tapered vertical shaft) stops when the level is too low... hence, those heavily loaded (and now uncooled) upper pinions melt together catastrophically.
In inboards and V-drives, the shaft log seal is a graphite or wax-impregnated rope, and it, like propshaft lip seal, is lubricated by lake water.  Spin that shaft dry for long, and the stuffing box will fail to seal, and in the case of a boat that'll be stored in the lake, it will leak, swamp, and sink.
So it's better to drop it in gear, so that just doesn't happen... or in the case of my runabout, I have a heavily varnished plywood cover that drops over the end of the prop, larger diameter than the prop blades, and a bungee cord that goes around the front of the drive leg.  Not only keeps it from spinning, if someone walks up and bumps into the prop, it won't cut a big gash in their leg.  It's a surfacing cleaver, and it certainly lives up to it's name...  I got a few scars bearing witness ;-)
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 11:23pm
I’ve got an excavator and yes I cover the exhaust pipe because of wind and because of birds and flying objects, when I hauled my wd45 d262 repower, I put it on backwards so the rain cap does the job…
But I never thought of a gust of wind doing it, something I should do research on….
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 4:42am
I've hauled a lot of equipment through my career. I worked for NYSDOT and they required the exhaust be covered whenever equipment was moved.
I, personally, have never seen a turbo damaged from spinning dry, but I can't imagine that it would do any good by having the turbo spin with no lubrication. The "experts" say it should be covered, so why take a chance?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 11:46am
Some o skid loaders and those small tractors and mini excavators have turbos and people don't think to cover them when hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 12:58pm
Thanks for your thoughts and your knowledge about this topic.
I just always stuffed a rag in both pipes when I haul my 210
no matter how far I was going to keep it from turning dry.
And rags are cheaper than replacing a stuck turbo.
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 2:56pm
When I was younger I was employed by a dealer that sold red equipment. I did all the hauling of the red things, the rule was to in some way or other block the air intake on turbo engines.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 9:49pm
Cheap rags are way cheaper than a turbo even if you don’t believe in the theory. Spin a bearing dry too long and your gonna have failure so why risk it. I never thought about the prop on a boat so thanks to the poster for the tip on that one. My bass boat will be in gear or the prop will be strapped from now on. It is a 6 hr drive to Erie Pa each year to small mouth bass fish and to stop and say hey to Brenda and everyone at SLI!! I try to always play it save if it makes sense and in this case it does.
