WD45 steering bolster |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Topic: WD45 steering bolsterPosted: 19 Dec 2022 at 5:02pm |
I brought my 57 WD45 into that shop to do some work on it and I noticed the bottom of the steering bolster is leaking pretty good. It has the 4 bolt axle and there is no bolt on cover on the top like my 54 WD45 has. Can I leave the bolster on the tractor to replace the seals on the bottom, or do I have to remove it and flip it upside down? I don't want all the guts to fall out if I leave it on the tractor. Many thanks! Good time to fix up the front pivot too! ![]() Edited by DSeries4 - 19 Dec 2022 at 5:03pm |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5910 |
Posted: 19 Dec 2022 at 6:57pm |
Myron Sent you a Xmas Present. Check your email, and not under the Tree ! Gary |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34434 |
Posted: 19 Dec 2022 at 8:52pm |
the 3 bolt front bolster will have the rectangular top cover, the earlier ones had a square cover and 4 bolts. the true WD45 from factory will have a 4 bolt front support and a round press in cap that can be pried out or using a chisel to tap it up and out. Without the repair manual here, I would say to block the tractor up, take the wide front off, remove cover and look in and see if there's a cap screw or two on top of steering sector gear. Take them out and remove bolts underneath, maybe leave a bolt or two partially in to catch the assembly and then press shaft out of steer gear. Good luck.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Gary
Posted: 20 Dec 2022 at 8:14am |
JC-WI So the first 40,000 WD45's built in 1953 were not 'true WD45's' because they did not have the 4 bolt Support Plate or the round Cover Plate on top. Not sure where you get your info from, but I rely on the Allis Parts Catalog for the facts. 1953 at Serial WD 127,007 the so-called 45 Trans. with Curved Shifter 1953 at Serial WD 146,607 1st WD45 and 226 Engine, Snap Coupler Drawbar late 1954 at Serial WD 186,413 4 bolt front Plate and round Press-in Cover G ................................................................... corrected typo: 1953 to 1954, near the end ( 190992 ) of 1994 production ........................................................................ Lowest Diesel Serial on the Owner Registry is 201190 Edited by Gary - 21 Dec 2022 at 4:12pm |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1528 |
Posted: 20 Dec 2022 at 3:22pm |
Serial 186,413 is late 1954 not 1953. I have 175421. it is a 1954. They were true WD45. Later ones had a couple upgrades tho - not uncommon.
Edited by Ed (Ont) - 20 Dec 2022 at 3:24pm |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 20 Dec 2022 at 5:57pm |
My dad bought one of the last '53 WD's, it had the pin drawer bar which was changed to a Snap-Coupler. Also the snap latches were added.
groundhog55
Posted: 21 Dec 2022 at 7:43am |
They went to the four bolt plate when the diesel engine was introduced.
DSeries4
Posted: 26 Dec 2022 at 8:33pm |
Started working on tearing down this afternoon. Spent some time working on removing the round cap on top. I have it lifted up a bit, still more to go. For removing the entire bolster, the universal joint needs to be disconnected from the steering shaft. I see mine has a solid round pin keeping things together. Any ideas how to removed the pin? It's also under the governor - not the most accessible location! Next question: the manual specifies SAE 240 fluid for the bolster, however I do not see any fill plug in the top - just a grease zerk. Very confusing! Can someone clarify? ![]() |
plummerscarin
Posted: 27 Dec 2022 at 6:19am |
I used a pitman arm puller to drive out the pin. It took a series of small nuts stacked up as the pin pushed through. There are photos in my "Dads WD project" thread. Admittedly, I had the side frame off for better access but the whole tractor was coming apart anyway
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5090 |
Posted: 27 Dec 2022 at 6:30am |
I have used John Deere cornhead grease in things that call for very heavy grease/oil that can't be found anymore. It comes in tubes that go in a grease gun.
DrAllis
Posted: 27 Dec 2022 at 6:33am |
I would use John Deere cornhead gearbox grease only if I couldn't find Hugger cornhead gearbox grease. There could be some kind of bad chemical reaction to Deere products being used in an A-C.
Gary
Posted: 27 Dec 2022 at 7:03am |
I totally agree with the Dr. The last thing you want Myron is for 'Greene Blood' leaking out your new seal. Gary |
DSeries4
Posted: 13 Jan 2023 at 8:33pm |
More questions: 1) What is the best way to remove the solid pin on the universal joint? I am reluctant to use heat as I do not want to cook the grease in the U joint. 2) What is the diameter of the hole in the U joint? Can a regular roll pin be used when reinstalling the bolster? 3) What is the best way to grease the universal joint? I do not see a grease zerk on mine. Many thanks!
Gary
Posted: 14 Jan 2023 at 6:17am |
Hi Myron
Are you sure it is a 'solid' pin and not a spring pin packed solid with rust ? I'd try running a small drill through the middle of the pin. I'd remove the Side Rail to have better access to the Universal. You'll be removing the front 4 bolts and loosening the rest in order to remove the Bolster anyway. As a last resort, if it is a solid pin, I'd drill the outer ends of the pin on the Bolster side of the Universal to weaken it, then twist the steering shaft to sheer the remaining pin. I see replacement Universal Joints have a Grease Zerk. Gary https://www.amazon.com/Steering-Chalmers-Interchangeable-70224825-70224825GV/dp/B08C8YNC9Y Pin 912855 3/8 inch |
plummerscarin
Posted: 14 Jan 2023 at 7:16am |
Mine is also a solid pin. This was my solution. Apply pressure to pin tap the end of the pusher bolt. Rinse repeat. I stacked small nuts over the pin as progress was made
![]() ![]() I used a flat chisel to work the cover up out of hole. |
Gary
Posted: 14 Jan 2023 at 8:59am |
Wonder why Allis didn't design the Cover with a flange similar to the later Belt Pulley Delete Cover Plate. G |
DSeries4
Posted: 14 Jan 2023 at 9:29am |
Hi Gary, it's definitely a solid pin. I have all the bolts holding the bolster loosened and I am planning to remove the left side frame rail so I do not have to deal with the belt pulley seal on the right side.. The existing U joint is still very good. No slop in it, so I prefer to keep using it. However I would like to grease it when I get everything apart. I will take a closer look, but I don' t recall seeing a grease zerk...
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8744 |
Posted: 14 Jan 2023 at 9:48am |
I use a hammer and punch from bottom side on those pins.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4198 |
Posted: 15 Jan 2023 at 7:55am |
I believe those pins are still available from AGCO. My NF u-joint was sloppy so I got some drill rod 1/32" bigger, reamed the hole to size. That tightened things up a lot.
Gary
Posted: 15 Jan 2023 at 8:47am |
Myron Once you get the Universal removed, disassemble it and see if it has grease passages from the centre of the X out to the 4 bearing locations. If not I think you are SOL as far as adding a Zerk. But for the amount you will be driving it, I would just clean and repack. Gary |
tom51
Bronze Level Access
Posted: 15 Jan 2023 at 9:50pm |
New U- joint inserts are available for DJ’s for less than 20 bucks and they are greasable
