temp gauge
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Topic: temp gauge
    Posted: 26 Nov 2022 at 3:03pm
got a new temp gauge for my 55 wd 45. anyone have any tips for getting old one out safely?
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Dakota Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 3:09pm
Take the hood off so you can get a proper wrench on it mine came right out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 4:05pm
thanks. even bad engineering in them days having to take hood off for want of a bigger access, lol.
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 4:21pm
I've not changed very many but hood off is the first step. Lots of penetrating oil would be a smart second step, allowing it to creep into where it needs to be. I guess a really stubborn one could require some very careful torch heat to loosen the hold. The old gauge is junk anyway, right ?  Take a cutting disc and whack off the gauge body to just above the nut and very gently use an impact wrench to very lightly hammer away with a six-point socket. This of course after using liberal amounts of penetrating oil and letting it soak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 5:01pm
I must have got lucky, mine came right out on the CA and the WD. I used Kroil and let it soak overnight.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 7:02pm
It's been a while but as I recall soaked good and then used a good Vice-grip and may have even used that trick of slight tightening it and then backed it out.  I'm pretty sure it was an original on a WD 45.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 10:46pm
My wd one came right out, but I had the tractor running before it did it…
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 12:52am
I've always done like Dr Allis said and cut off the stem.  Soak them good and put a socket on it.  If I have to save it for some reason I would probably try a line wrench.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 7:36am
I've changed two or three of them, don't think a line wrench will work, had that thought. What worked for me is a knipex tool, called a pliers wrench. Kind of a cross between a crescent wrench and a pliers. Your mileage may vary. The Dr. has a good plan.
