Sowing orchard grass
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Topic: Sowing orchard grass
    Posted: 25 Nov 2022 at 11:07am
I know this is off topic but need some advice. Next spring going to sow a 16 acre field in pure orchard grass. So I cut last cutting of hay (played out alfalfa) 2 months ago then 3 weeks later sprayed with roundup. Took soil samples and after everything was brown, field was chisel plowed. Next spring going to disc once then apply fertilizer. Then disc again and get it smooth as possible. My question is, what would be the best way to sow it? We have a 3 pt. spinner spreader and a 10' Brillion sure stand seeder with  2 seed boxes.   Would 1 of these work or would something else be better? Thanks for any advice!!!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 11:30am
If you spin spread it I would personally have to run a coulterpacker over it which means 2 trips over the field. My choice is to drill it in. Good luck.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 2:04pm
Is the brillion seeder a cultipacker style?I'm guessing it is.If so that would be my choice.That's what dad and grandpa used to seed sod fields.It's also what I've used to replant my hay.Does a good job and gets it on at the right rate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 4:23pm
Orchard grass doesn't need a lot of covering. Good contact is all it takes. I would drill it if I had that option. Most times here we will mix wheat in it to get a stand so it doesn't wash. Wheat will die with first cutting, grass will come up and thru stubble. Personally I would try to get a fungus free type strain. JMHO, Tracy
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 4:31pm
Brillion seeder provide accurate seeding rates and adequsoil compaction for seed contact. By me ,we have peerless seed company. Lots of modern varieties
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 5:11pm
Always just braodcast it then drag it with a cedar tree, always had good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 5:32pm
I vote for the brillion, seed and pack in one pass.  And you can pull a 10' brillion with a small tractor, as long as the hills aint too steep...Thumbs Up
Edited by DiyDave - 25 Nov 2022 at 5:33pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 7:19pm
Mix the orchard with one to two bushel of oats. Some guys have rate issues with fluffy seed in brillon seeders. I have started rolling fields before and after seeding with the drill. A field this year just got dragged smooth after seeding with the teeth set shallow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 10:17pm
I help a good friend on his farm, he makes 20- 25k square bales of orchard grass a year. He does it both ways with great success. He also no tills. Several factors come into play when deciding which way to seed. Actually use the no-till and a Massey drill on ground that was sprayed, disced, and packed. Makes a nice seed bed. Once its seeded, the Brillion is ran over it again to ensure coverage. Sounds repetitive, but with todays fast moving hay processing, the ground is nice and smooth making it easier on equipment especially the Krone fast moving rakes and the Bale Baron.
Using a spreader works well also once the ground has been prepped, mixing fertilizer with the seed. Run the Brillion over it and its done. This is done when we are pressed for time, rain forecasted, or hay is ready in other fields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 10:48pm
Brillion cultipacker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 7:53am
AC720 you are right about having fields smooth, if we make 3 to 5 crops a year with the rotary discbine rotary rack and big square baler most of those operations now take place in the 5 to 10mph range. It's nice to not be bouncing all day.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 8:26am
We also pull 2 -16’ telephone poles after disking to level the field smooth before running the Cultipacker, makes the field smooth as butter. Use the 175 diesel for this task in 6th gear for the first pass, and then 7th gear for the second round. Fields will last 4-5 years before the no till is run through to reseed when necessary.
Edited by AC720Man - 26 Nov 2022 at 8:30am
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 10:53am
If you decide to use the spinner spreader, you need to seed on a calm day. Back when Dad used to sow hay, we would mix alfalfa seed with some orchard grass, and if the wind was blowing the orchard grass came up in strips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 8:03pm
Thumbs up!!
