c drag link
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: c drag link
    Posted: 20 Nov 2022 at 9:22pm
what is everyone doing to replace the drag link ends when they are wore out ?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 5:50am
Find weld on ones with the right tapered end and do a measure/cut/weld.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 8:31am
https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
after clicking on above, it will go to a generic page and stop... UP in the LINK at the top of the page, click on the link and backspace to eliminate the %20 .... then hit enter.. You will go to the generic steering link page... I would just match one up as mentioned..
Edited by steve(ill) - 21 Nov 2022 at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 9:21am
anyone got a paticular part number
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 6:15am
I used TRW es150r
This page was generated in 0.107 seconds.
