Mystery H3 serial number
PaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaDon Quote  Post ReplyReply Direct Link To This Post Topic: Mystery H3 serial number
    Posted: 17 Oct 2022 at 8:04am
Hello folks, new member here. I just bought an H3 track dozer and I'm trying to find the year it was made. The number stamped into the torque tube is "H3  1501". The serial number lists I've seen don't show that number. Does anyone know when this was made? Thanks, your posts have been very helpful.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:24am
Tractor Data.com shows 1961
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 5:22pm
Per C.H. Wendel's book, same, 1961Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaDon Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:57pm
Thanks, you all. It's been restored once and has at least 95% undercarriage but the right drive sprocket has a little wobble in it and rainwater got down the exhaust. I changed the oil and it turns over and has compression but I'm replacing all the ignition and gonna pull the head off and have hardened valve seats if it hasn't already been done and check the rod bearings. Then that final drive....ugh.... I'll put a picture up when I figure out how to do that.
