fungicide on beans
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: fungicide on beans
    Posted: 10 Oct 2022 at 7:55pm
how many people spray fungicide on there beans?  This was a first for me this year.  It seems like they thrash rather hard any one eles experience this? I have my rotor on my r-5 damn near all the way open  its thrashing all the beans ok with out the pods but it just seems like its taking every bit of power i can squeese out of the old girl
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 8:44pm
It keeps the stems greener and healthier. Beans will be dry with green stems.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 8:52pm
Use fungicide on every acre.Makes then cut harder, thresh harder,and you’ll burn more fuel but on our side by side tests it more than pays for itself. Just not so sure about the aggravation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 9:00pm
I decided to try to chase my bean yield i usally average around 50 where every one eles are in the 60bu  i was told to try fungicide and did we had timely rains my beans were 3 ft tall and i believe im pushing 70 bu  im amazed but its working the out of my machine may need to cheat and back off a row
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 6:31am
Good results here too. They have convinced me to, it pays
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 8:21am
First season for the N-5 ???????     Probably needs new helical bars in the cage and get rid of the reverse bars on the left side of the rotor. Those two things will reduce HP requirements drastically.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 10:32am
X2 on taking the fun out of cutting beans but agree with the ROI
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 11:49am
Does row spacing affect the need for fungicide? I plant 30” rows, have not applied it, and seed man seems to think going narrow rows would not benefit me
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 12:41pm
Around here my supplier says good for 10 bu increase as a rule. It can vary but seems about right. Early planting improves chances. At a ball game last week and retired neighbors boy sent video of monitor as we were watching game. 10% /100-108 bu. April planting w/fungicide. Greene combine....was it calibrated right? Just reporting...
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 1:32pm
I do 30 inch rows as well.  And the seed man and AGRONOMISTS (jayWink) around here say that yes, 30 inch rows are less susceptible to fungi problems.  White mold is the common one in the conversations.  Stands to reason, more airflow around the plants for a longer part of the growing season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 7:38pm
r-5 DR.  ive had it for about 10yrs on 80 acers  never flipped the bars
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 7:43pm
We have been doing fungicide and Ascend growth regulator for several years here in Southern Indiana. Cost per acre this year was 46/acre custom applied and we figure routinely it has been 6 - 10  bushel increase so 12 -14$ beans it certainly is worth it. we have an older 9510 John Deere conventional and just pinch the cylinder down against the concave and it chugs along in green stemmed beans but it does drink the fuel!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 8:07pm
Helical bars are bolted inside of the cage and spirol the fodder thru the cage to the exit point. They are a wear item. When an auger is worn, it doesn't work very well. When helical bars are worn they don't work well in green/tough conditions. "Reverse" cylinder bars need to be removed and replaced with "forward" bars to improve the flow of fodder thru the cage. These are things I always did to increase the appetite of those P-1 processors, decrease rotor losses and cut fuel use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 8:20pm
thank you
This page was generated in 0.127 seconds.
