Starter Electrical Problem |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8482 |
Topic: Starter Electrical ProblemPosted: 20 Sep 2022 at 8:53pm |
Working on an off color riding mower (anyone got an old Allis rider for sale?) and I’ve hit a wall. Problem was I could turn the key to start and you could hear the bendix engaging, but you’d have to turn the key off and back to start position a dozen times to get the starter to actually turn. Then it would crank fine. Recently everything quit. No solenoid clicking, even though battery is fully charged. Decided to take the starter off, which was a big chore in itself. Hooked jumper cables straight to the starter after I removed it and the bendix extends and the starter turns, every time I put power to it.
At the ends of the 2 starter wires, the battery cable has 12 volts, as does the solenoid wire whenever I turn the key to “start”. Every time. Tested it over a dozen times. When I hook the wires back to the starter, they both still have power when key is in “start” mode, and even with a dedicated ground wire on the starter (starter still removed from engine at this point) there is no response. I can’t figure out why it works fine when hooked direct to the battery but not when hooked to the wiring harness, even though it has 12 V going to it, and a dedicated ground wire running from the clean starter to the clean negative battery post. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8989 |
Posted: 20 Sep 2022 at 9:16pm |
Got a Simplicity Zero with similar issue. Has to be bad connection but haven't found it.....just keep twisting key. Know this. Just because you have 12V at the end of a wire doesn't meant the connection will carry the amps.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 20 Sep 2022 at 9:26pm |
YEP... solenoid is bad or one of the cables is rotted end on it.. Your getting 12 volts, but not enough amps to move the starter... jumper across the solenoid with cable / pliers and see if it cranks.. check cable ends for corrosion... bad ground on strap.
CrestonM
Posted: 20 Sep 2022 at 9:34pm |
I'm going to go take a better look at the ends of the cables tomorrow. Could be internal corrosion of the positive battery cable I suppose? I've seen it once before, but what causes that?
Leesok
Posted: 20 Sep 2022 at 10:30pm |
Go buy a new battery
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 21 Sep 2022 at 6:32am |
![]() As everyone said, you have a weak connection somewhere, showing power, but not carrying current.
CrestonM
Posted: 21 Sep 2022 at 7:30am |
Load tester shows it's good.
Stan R
Posted: 21 Sep 2022 at 7:32am |
Get a set up jumpers and connect + to solenoid and starter lug from + battery.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11416 |
Posted: 21 Sep 2022 at 8:05am |
I had one that it would quit running but if you was fast enough at wiggling the key it would keep running, replaced ingition and problem solved
CrestonM
Thanks(1)
Posted: 23 Sep 2022 at 11:59am |
Ended up replacing the positive cable as well as the key switch since the dealer had one on hand. The old cable did appear to have internal corrosion after I cut the end off to get a better cross section view. Back up and running now!
Thanks guys |
plummerscarin
Posted: 23 Sep 2022 at 12:26pm |
Thanks for letting us know
