Screw "A" Location WD45
Whittwhitt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whittwhitt Quote  Post ReplyReply Direct Link To This Post Topic: Screw "A" Location WD45
    Posted: 05 Sep 2022 at 9:08am
Our '57 WD45 is having trouble with the 3 point wanting to drift upwards or downwards when it should be holding in place. We've looked online at the diagram that tells you what screws to tighten and loosen, but we're having trouble locating screw "A". Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whittwhitt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:11am
Also - please explain things as detailed as possible if you can, even with pictures. We're just starting out and are learning as we go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:15am
Owners manual has a picture. Decal on the side of the battery box does too.  Screw "A" is located behind the right side frame with the PTO push/pull rod running right by it. There is a divot on the side of the hydraulic pump body that the tip of screw "A" must screw into. Do NOT overtighten as it will bend things !!
