Allis Chalmers C
Timmydou65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timmydou65 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C
    Posted: 27 Aug 2022 at 1:30pm
Just bought a 1947 Allis Chalmer model C.
My amp meter Box has the amp meter, 2 toggle switches, and a push button. One of the toggles operates the headlights, 1 activates something else which I've traced through a fuse but not to a thing, and I cannot figure out what the push button does. Any help would be appreciated.. Thanks. Timmydou65 from Texas
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 3:48pm
some have installed a push button for a starter... Does yours have the PUSH ROD to the starter motor, or does it have a SOLENOID installed in the circuit..
Toggle for the lights... The other is an ignition ON switch or a magnito KILL switch.
below is the wire diagram on mine..... it has an alternator, not a generator...
Edited by steve(ill) - 27 Aug 2022 at 3:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timmydou65 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 6:12pm
Thank you. Mine is still a pushrod starter.
Ignition switch makes sense. Thanks
Just have to figure out the button.
Appreciate the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 7:12pm
If you have a magneto its possible the push button is a KILL BUTTON for the mag.. hold it down till the motor dies, then let go.... On a distributor, you would need a toggle switch for CONSTANT power to run............ how do you KILL the motor right now ?
But if the button is the KILL, then you still need to see what the other TOGGLE is for.. possibly a rear light or ?
Edited by steve(ill) - 27 Aug 2022 at 7:13pm
