Which is the best AC engine? |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5249 |
Topic: Which is the best AC engine?Posted: 15 Aug 2022 at 9:28pm |
Curious to see what everyone thinks is the best AC engine that was built and why?
301, 426, 226, 149, 160 CI, or others I didn’t mention. For me its the 301. It came naturally aspirated, turbocharged, turbo charged and inter cooled. Mass produced over many years, installed in tractors, combines, stand alone pumps, power units, and other equipment. Reliable, makes good power for the cubic inches and is fuel efficient. |
jlogli
Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
Posted: 15 Aug 2022 at 9:31pm |
226 gets my vote.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Codger
Posted: 15 Aug 2022 at 9:45pm |
Posed the same questions several times. The 301ci is probably my pick also as was so versatile. The 426 if kept under 200hp was very good also for the larger tractors and power requirements.
I like the 516, and 844 engines also as most were dead reliable.
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Posted: 16 Aug 2022 at 5:30am |
I have to say they all get my vote! Top of my list of the best would be the 301 and 226. But they are all incredible.
Blue Skies and Tail Winds
Dana |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Posted: 16 Aug 2022 at 5:36am |
226 gas and 301 diesel. AaronSEIA
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4127 |
Posted: 16 Aug 2022 at 8:09am |
Not going to pick a favorite, haven't encountered one I didn't like. I do favor the 301 and 226 but the 125's in CA's are pretty impressive too. You can mow a BUNCH of grass with a tank of gas in the CA!
DougG
Posted: 16 Aug 2022 at 8:28am |
301 Diesel no doubt at all
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1164 |
Posted: 16 Aug 2022 at 9:28am |
The 433T or 433I. Very high longevity, very low fuel usage, lots of torque rise and sounds like mad bumble bee. Biggest downside is cold weather starting
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
ACjack
Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 277 |
Posted: 16 Aug 2022 at 9:39am |
Don't forget it also was produced as a gasoline burning engine. Designation G2800
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8731 |
Posted: 16 Aug 2022 at 11:04am |
My two most useful tractors are my one ninety XT, with the 301, and my 7060 with the 426. Couldn't pick a favorite of the two, because both have specific duties that are really not so much interchangeable
Darrel |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5119 |
Posted: 16 Aug 2022 at 12:16pm |
It is hard to argue that the 426 being developed in the early 60's can still be found working every day, isn't among the best AC built. They should have increased the cubic inches instead of turning it more rpm though. Look close at an IH DT414,436,466 and it resembles the AC 426 to some extent. One has to wonder how many engineers went from one company to another. When IH built their engine, they did make a few improvements, like a taller cylinder head, and increase in cubes. I've always felt the 301 came after the 426 as a smaller sibling. Much of the design is shared between the 301 and the 426.
Edited by injpumpEd - 16 Aug 2022 at 12:17pm |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 16 Aug 2022 at 9:05pm |
I agree with Ed on the increasing the 426 cubes to get more power. I also think if they would've offset the rod caps like the IH engineers did, they could've used bigger rods and rod journals and held together better at higher RPM.
Personally having both a 2800 diesel and a 670T, I really like them both. My vote is going to be for 426 though, so long as the RPMs are under about 2500. But the 226 definitely deserves recognition. Thinking about how it started life as the 201 in about 1935, and was slowly morphed/adapted and used in tractors, combines, and cotton strippers through the late 60s is indicative of its reliability.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 17 Aug 2022 at 6:31am |
Last 226 would have been in the 175 tractor (1980 last year).
45 amazing years for that design 301 and 426, which one came out first? I guess the 426 gets the nod for largest HP increase from 100 hp to 180 at the high point.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
CrestonM
Posted: 17 Aug 2022 at 6:43am |
I stand corrected! |
Charlie175
Posted: 17 Aug 2022 at 6:46am |
I have an error, looks like 1976 was the last year they offered the Gas motor on the 175.
Charlie
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 17 Aug 2022 at 6:48am |
Regardless of our preference of the AC engines, the "newest" ones are 37 years old and a lot of them are a lot older than that.
I wonder how many of the engines in tractors that are being built today, will be around in 37 years? I'm betting, not many!
walnut1
Joined: 11 Nov 2017 Location: California Points: 42 |
Posted: 17 Aug 2022 at 7:13am |
I’ve had a 190, 190xt, 7020, 7040, 7060 over the years that were good but had issues from time to time, but the 516 in the two HD11s and 11 series B were NEVER a problem. Those tractors and their engines were incredibly reliable for me.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3576 |
Posted: 17 Aug 2022 at 11:41am |
426 mark II diesel engines 1974-1981(7040's 3500-670T, 7060's 3700-670I, 7080's 3750-670HI) Deep-skirted block, Piston cooling system, cross-flow heads (exhaust/intake on opposite sides of head), Intake/exhaust valves alternate the full length of the head(less hot spots), Intercoolers drop intake air temperature after the turbo, high capacity oil cooler, 4.25"bore x 5"stroke, 16:1 compression ratio, 1310Lbs (3500-670T) net weight basic engine, 15qt (standard oil pan) crankcase capacity, 4qt-3500,10qt-3700/3750 oil filter capacities, 14qt (engine only) cooling system capacity 31qt-3500,32qt-3700,36qt-3750 total cooling system capacity, 64gpm@2400rpm water pump capacity. Edited by AC7060IL - 17 Aug 2022 at 11:45am |
injpumpEd
Posted: 17 Aug 2022 at 11:44am |
But the 426 came out in 63 in the D21 first as the 3400 naturally aspirated engine. I'm not sure of any other offerings back then. The 301 is a smaller version of the 426.
AC7060IL
Posted: 17 Aug 2022 at 11:52am |
DrAllis
Posted: 17 Aug 2022 at 11:53am |
Mark II engines were second generation with the oil filters upside down. 1973 to the end. First generation 3400-3500 engines were from 1963 until late 1972 in farm equipment. It does seem that A-C still made first gen engines for generator sets for many years after 1972.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
Posted: 17 Aug 2022 at 1:08pm |
As for the engines I think they'll last as long as old engines no problem. Today's metallurgy, manufacturing methods and technologies, and quality is second to none. As for keeping them running as is with all the computers and emissions requirements, not so much.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88465 |
Posted: 17 Aug 2022 at 2:58pm |
YEA.... the quality of the MOTOR today is as good or better than ever as Tbone said.. Most have a lot more HP per CID than the older versions... Biggest problem is going to be the "technology" that makes them run.... as mentioned.
DanD
Posted: 17 Aug 2022 at 9:27pm |
While the 175 tractor was built until September of 1980, the 226 gasoline engine option ended in 1976. It was the last AC gasoline powered tractor.
steve(ill)
Posted: 17 Aug 2022 at 9:42pm |
Bigger motors are always discussed when talking about the BEST... Another consideration is the CE motor used in the B, C, CA, stationary engines and gen sets.... There were something like 128,000 B and 70,000 C built over a 20 year period.... Thats something to be proud of.
AC720Man
Posted: 17 Aug 2022 at 10:10pm |
All good points made. I will add the 160 in our series II D15 has been a trouble free engine until the oil pickup came loose 54 years after it was built. Even a poor design oil pickup worked that long! AC made great engines IMO, across the line. Some better than others. The 433T and TI are good engines also, it’s fault, cold weather starting which is resolved by plugging in the heater for awhile before it’s used. Give it an hour and she always starts. I’m guessing the 201,226 were most likely the most produced engines. And the little engine with a big heart is in the CA, bullet proof, and as said mows grass on our farm with a 6’ belly mower like it’s not even there. Always thought the 426 was a beast but I’ve never owned one.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
Posted: 07 Sep 2022 at 2:40pm |
My vote goes to the 516. From what it started as to how it finished, and still had great longevity is impressive. |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |
Posted: 08 Sep 2022 at 12:23am |
The 'best' engine is very subjective. That's like saying "My Favorite Beer"... is the one I'm drinkn' right now... The BEST AC engine ever made, is the one in the machine I'm operating right now. ...whatever that machine is, and whenever 'now' is... There's at least a hundred different metrics by which one could 'rate' one against another... but in a 'best overall', there's really no point in attempting, simply because each motor design occurred as a result of the circumstance for THAT powerplant, at THAT time. Clearly, later generations of engines managed better fuel economy, and more power, but every step of metamorphosis along the way presented opportunity to advance, and AC certainly didn't IGNORE opportunities to improve. The industrial engineering aspect of ALL AC motors is amazing- they really knew how to design things to be MANUFACTURED, and they didn't overlook how they were to be maintained and overhauled. It's this kind of thing that nullifies any notion of 'best', as every darned one of the Allis engines had it's characteristic superiorities.
ajl
Posted: 20 Sep 2022 at 10:21pm |
I would say the best is the one in the tractor in the yard. For me it is the 426 in the 8070 in the yard. Now that harvest is almost done, I will start disking sloughs. This is a ritual performed every year when it is dry in the fall with the idea that we will seed through it rather than around it next year. Every year run off refills the sloughs so they grow cattails like every other year. But hey, I get to listen to the 426 under load doing this so that makes it all worth it.
