180 or 185 |
Post Reply ![]() |
randy ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1217 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jul 2022 at 9:11am |
I have been thinking of getting a 180 or 185 tractor and selling my D17 diesel and CA.
Anything other than a gear jumper, that need to look out for?
rickymotorbrains ![]() Bronze Level ![]() Joined: 25 Jan 2019 Location: dry ridge ky Points: 56 |
if it blows the hydraulic oil to back half from the pto seal between trany and rear end
Tom59 ![]() Bronze Level ![]() ![]() Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 155 |
My thinking is keep your D-17 diesel and CA tractors. Then look for the best 180 or 185 you can find. I kept the first tractor I brought when I upgraded to little bit larger tractor plus a cab with air conditioning. Plus I never regret keeping it. Just my opinion.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3041 |
I don't know how to check for this but if it occasionally dies than starts back up easily. The pump needs rebuilt.
Check the brakes. Put it in 4th and mash the brakes - see if if the clutches slip in high or low
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
buy a 6080 or 6070 instead
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5001 |
We could point out advantages either way (60 series vs. 100 series), but I, personally, would much rather have a 180 or 185.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8327 |
Ive always luved the hum of a 301 in a One Eighty diesel- have a fond for them , worked for a fella that had one from new 1968- tractor prolly had 20,000 hours on it as he went all over baling hay , crops , had it worked on at an AC dealer when needed, one engine overhaul, brakes , and a 4 th gear replacement - tractor wasnt abused but did what it was designed for - Id go One Eighty
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33809 |
185 at least can have 540/1000 pto, essentially same tractor otherwise.
Very true there, 185 has that option
185 would be my first choice, but seem to be more 180s around
cwhit ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Sigel IL Points: 992 |
Just get one of each. :)
I think it odd that according to TractorData there about roughly 3000 more 185 built than 180 tractors. But I noticed that you can find more 180 for sale, hardly any 185. Are people keeping their 185 because they are more popular ? |
Great idea cwhit!!!!!!
mruhlig77 ![]() Orange Level ![]() Joined: 19 Aug 2014 Location: central Indiana Points: 589 |
The 185 seems to have the reputation for more long term value...both nice property to own....
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5090 |
keep in mind, 185's were built into 81, so some could be much newer. But remember the 180 came in 67, through 73? 185 came in 70, so 3-4 years of being built consecutively. Either one will be a step up from a 17.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21776 |
The reality is this: if you owned a D-17, especially a series 3 or 4, when you traded for another new Allis, you didn't buy a One-Seventy. You moved up a size or two and bought a One-Eighty or 185. Think how many sales of a gasoline One-Eighty were missed out on for nearly two years of diesel only models. That was a shame.
ranger43 ![]() Bronze Level ![]() Joined: 09 Jun 2019 Location: Huntingburg Points: 154 |
X2 I had a nice 6080 2wd cab/AC sold it bought a 1 owner late model 185 and enjoy it a lot more. I grew up on a 170 diesel so I just like the layout better. I agree both have positives. 6080 is a good tractor, just lack of a power director, no detent on 3pt. hitch hydraulic lever and few other things just didn't suite me, but I know a lot of guys think the opposite.
Trinity45 ![]() Orange Level Access ![]() ![]() Joined: 17 Mar 2014 Location: Kentucky Points: 1892 |
Don't think there is much difference between the two, except the PTO and Some 185 like mine came with a large rear tire. Pretty much the same other wise.
bemer848 ![]() Bronze Level Access ![]() Joined: 29 Sep 2013 Location: southern IL Points: 93 |
Dad bought a new 180 in 1970. A few years later we were at the dealer, and they had a 185. Looked like the same tractor. Dad asked the dealer why the 185 was rated at higher hp. Dealer said they both had the same power it was just that nebraska test 185 was tested at 200 higher rpm. And that on their dyno the 180 always had more hp then they was rated at.
If find one with the five rail thirties on back, BUY IT!!!!
Well, i found a 180, pretty good shape. Diesel, good tires, only 1 small dent in the hood. 4914 hours on the tack, but its not working, rpm works. Runs good.
Tried to load pictures from my phone, no go. Used it on the mower Saturday and everything works as it should! Thanks for all the info Randy
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
wish i could find another good 180, the one i have has been one darn good tractor.
[IMG]http://[/IMG][IMG]http://[/IMG]
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5213 |
Send the tach to Star Speedometer so Haim can fix it for ya. Glad you found a tractor you wanted.
That sounds like a pretty nice tractor by your description ( I think your description is on target by you being the buyer instead of the seller ) and specially sounds nice being a fifty year old tractor. I been following your post and like hear more comments as you used your new tractor. Sounds like a great find. |
Well, i got 1 picture to load twice, having problems, says file manager is full.
Could someone post pics for me if i text them to you? Thanks, Randy |
Michael (WI) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Larrabee, WI Points: 815 |
Something about taking off a piece on the pump and removing a ball is a temporary fix when the rubber governor ring comes apart and blocks up the return. If this is done on any diesel you look at is only mater of time until a pump rebuild. I have a 185 with five rail 30's on back that I use to cut hay and plant corn with a AC 330 planter, narrow four row with a monitor. My youngest two like to go on the tractors and pretend to drive them.
Post Reply ![]() |
