Gleaner chopper question |
Northern Hoser
Topic: Gleaner chopper questionPosted: 14 Jul 2022 at 9:01pm |
Hello all, putting new stationary teeth (concave) in my L3's chopper, fresh from AGCO they seem dull, but definitely better than the old ones.
Should I sharpen these before I put them in? I'm guessing they should go in as is but thought I'd ask. Thanks. BTW flail blades are good, nice flat edges
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2339 |
Posted: 14 Jul 2022 at 10:07pm |
I would say just use them that way, more medal to wear off.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8995 |
Posted: 15 Jul 2022 at 11:28am |
The knives do the cutting. They need something to whack against. The factory concave is fine as is. I doubt you could tell the difference if you sharpen them.
Edited by SteveM C/IL - 15 Jul 2022 at 11:29am |
Northern Hoser
Posted: 16 Jul 2022 at 8:24pm |
Ok thanks, other forums suggested that the spinning flails should have a square dull edge and these concave teeth need an edge on them.
One guy said he sharpened the flails and it made it worse. It works ok now but had several missing teeth, $16~ a piece from AGCO in Canada Matt |
SteveM C/IL
Posted: 18 Jul 2022 at 10:49am |
The edge of the flails isn't that picky either. What you have to pay attention to is the corners getting rounded off. Round corners won't grab damp straw. Next thing you know you are baling the back end and wrecking walkers and cranks.
Unit3
Posted: 19 Jul 2022 at 11:11pm |
They sharpen them in the rotary machines.
SteveM C/IL
Posted: 20 Jul 2022 at 10:30am |
False blanket statement. My 97 R62 is just like the conventionals only blades are some bigger. Have seen S? series with fine cut chopper had sharp knifes.
