Do Farmall A weights fit AC b/C/CA?
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Do Farmall A weights fit AC b/C/CA?
    Posted: 09 Jul 2022 at 9:13pm
I found a junk Farmall A with front and rear wheel weights. Do they fit AC rims?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 6:20am
Interesting question. I have a set of said weights, will have a look today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 6:43am
  NO: Those rear wheel weights are for Dished wheel centers as the NON PAW wheels that sometimes are on D10/12 tractors, if you has those wheel, they will fit.
  Although the complete rear wheel rim/assemblies do interchange onto a CA, The Farmall A/B weight will not fit right on The AC CA PAW wheel centers.
  Although for the Farmall weight may fit somewhat onto an Allis B or C wheel. Depends on how well you want them to set on the wheel.
 As for the Farmall front weights they mount in a completely different fashion.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 9:08am
i don't know  if they fit but my farmall super a on the rearend weights are not the same weight transmission side of the tractor is lighter then the other side so that the tractor weights the same both side
This page was generated in 0.083 seconds.
