Packing for a sediment bowl assembly
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Packing for a sediment bowl assembly
    Posted: 09 Jul 2022 at 9:14am
What should I use for packing? Can I find it locally?
My luck with new assemblies is like my luck with new water pumps. They leak. I’d rather fix my old one if possible.
This one in particular is for a WD45 if it matters.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 9:43am
I get mine from the local plumber. That is if you are talking about around the shut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 9:44am
Yes
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 10:18am
I just used teflon tape, rolled it so it was rope-like and packed the packing nut best I could and put the packing nut back on. 15 years ago and still holding....
Edited by Stan R - 09 Jul 2022 at 10:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 12:17pm
Just did the same.
Hope it lasts but for now my $4.58 gas isn’t continually dripping away.
Felt tension on the shaft like it should.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 6:12pm
I wound up buying a piece of graphite valve stem packing, and it has lasted about... 8 years now on my WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 12:02am
Well,I tried dental floss on a water valve stem where the old rubber was dried out and cracked. So far so good but then it's not gas.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 11:27am
Interesting topic.  This just happened to me on my WD this weekend.  I gave the "nut" a 1/4 inch turn and it was all fixed.  So, I must of "loosened" it somehow when I went to turn the gas off.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 7:08pm
Yes, I unraveled a little of the graphite valve stem packing (bought at local hardware store) to get a smaller thread for that valve, it has been OK now on the WD for more than 20 years!
