D17 G226 any 4" piston kits still available
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Topic: D17 G226 any 4" piston kits still available
    Posted: 05 Jul 2022 at 2:00pm
Does anyone still offer a 4" bore sleeve & piston kit for a G226? I have part numbers for the OEM kits of varying compression ratios, but local dealer says they are all NLA. I don't really want to use a 4-1/8" kit if I don't have to, as years ago when I worked at an Allis Dealer it seemed like tractors would come in with coolant in the cylinders from a broken  sleeve flange and they always had the 4-1/8" S & P in them. This was 45+ years ago so maybe something has changed with the quality of the liner and this is no longer a problem.
70257452 4" 7.25-1 C/R
70257458 4" 8.25-1 C/R
70257859 4" 8.00-1 C/R
70257457 4' 5.83-1  C/R
I would be ok with any of the above kits other than the 5.83-1 kit.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 2:32pm
I think maybe someone has 4 inch sleeves available. I was thinking about buying some of those and having custom Power Crater 8.0 to 1 pistons made for the 4 inch sleeves. Wouldn't be cheap, but I've always felt the 4 1/8" bores with no compression was just a giant step backwards in power and fuel economy.
Edited by DrAllis - 05 Jul 2022 at 2:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 5:42pm
The same website also shows an 8.25 to 1 kit under the 170 tractor. They call it an LPgas kit which would be correct for a D-17 LPgas.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 8:08am
We have a 175 piston & sleeve kit, 8.25:1 ratio, A-C #257548 in stock for $922.
Also have aftermarket piston & sleeve kit, 8.25:1 ratio with 4.125 bore available.
And NOS D17, WD45, WD pistons 229718 available.
www.awtractor.com
A&W TRACTOR 920-598-1287
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:39am
That is interesting. I few years ago I was looking pretty hard at 8.25 kits. I was able to find and buy a Reliance 4" kit but I never saw a 4.125 overbore 8.25 Kit. That would be a step up for those pushing for more power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:41am
1/8" overbore at the same compression ratio is probably 3 to 4 more HP at the PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:55am
I have sold one of those 8.25:1 4.125" bore kits to a customer who pulls his WD and has told me its working great! We also installed that kit in a local 170 tractor and that has been working great too! I would not recommend that kit with the WD/WD45 crankshaft or if the D17 crank has been turned down more than .010.
www.awtractor.com
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 10:23am
“ I have sold one of those 8.25:1 4.125" bore kits to a customer who pulls his WD..”
Putting a 8.25 compression ratio kit from a 170 into a WD (with 4” stroke) would lose a lot in compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 11:30am
It's good to know some of these options are available again. 5 years ago when I was buying there was only one 4" 8.25 kit left on the shelf with no prospect of another run.
Edited by Allis dave - 07 Jul 2022 at 11:59am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 5:49pm
A lot of guys have replaced the 201(4") WD crankshaft with a 226 (4.5") WD45 in the original 201 block. I think that's what Alex was talking about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 5:56pm
Good catch! Tractor was a WD45 not a WD. Hard to keep track of all the sales and repairs I make lol
www.awtractor.com
