D 15 oil change
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 oil change
    Posted: 15 Jun 2022 at 9:18am
Went to NAPA this morn . Counter guy said Rotella is unavailable . Anyone know of a good substitute ? Also wonder how often you fellas change the oil and filter in your low hour tractors ? Once a year ? THANKS !
Edited by ACinSC - 16 Jun 2022 at 8:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 10:17am
I was changing the oil and filter every year... Got a sickle and wood mower "B"s that get about 25 hours a year... I have changed that to keep the filter for a couple years.. they never get dirty... Might stretch out the oil change also.
I have been using a good 10w30 motor oil in several small tractors for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 10:32am
Thanks Steve . I was looking for Rotella mostly for the higher zinc additive . Prolly too late to worry about that anyway . Thanks , again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 8:20pm
Rotella SAE30 is available locally at Walmart and other auto parts store. Especially designed for older tractors with high zinc.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 8:40pm
Get some 15-40 at any truck store or TSC. Yes Shell is hard to get or at least the tier 4 stuff is. Our shop got of a bunch of Shell tier 3 that they are selling a bit cheaper. I got a pail of that. Perfect for the older units - don't need the latest spec for these old girls. Get some Mobil or whatever is in stock! The tier 3 Shell is in a black pail instead of the yellow and white pail.
Edited by Ed (Ont) - 15 Jun 2022 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 8:41pm
if your running your tractor HARD and over 250 hours per year, you might consider the zinc........ if your running 2 hour every other week to cut the grass 6 months out of the year.... go with the 10w 30.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 5:49am
My Walmart and TSC had no Rotella. I'll keep looking and figure something out. Thanks guys
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 6:18am
For older tractors, I would recommend Mobil Delvac 1200 series. Available in 15w40, and 30wt. Find a ExxonMobil distributor, they should have it in their warehouse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 10:11am
Finally bought some oil and zinc additive . Got my tractor up to 180 degrees . Pulled the drain plug and what first ran out looked the coolant to me ? Would coolant be in the bottom of the sump ? If it's coolant what could be the cause ? Blown head gasket ? THANKS for any help with this ! Should say this is a Series 1 gas engine , 149 I think .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 10:19am
If it is coolant, it had to come from the radiator. Is the radiator LOW ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 10:32am
I think it's a little low . Waited a min for it to cool down . Also when I first pulled the plug the oil/coolant felt cool and then got pretty hot . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 12:34pm
Just remembered back in March I noticed my oil fill/breather cap was pretty watery looking . Guess that was my first sign of a leaking head gasket ? Oh well
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2022 at 2:08pm
I have this suspect oil in a couple clear containers . I'll check it in the morn and see what I find . Thanks
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2022 at 7:14am
I bought Rotella at the Winfield Kansas, Walmart this week.
This page was generated in 0.091 seconds.
