WC Fender Support Bolts
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: WC Fender Support Bolts
    Posted: 29 Sep 2010 at 12:40pm
I got one long bolt that goes on the front edge of the fender thats bolts to the frame and keeps the fender from rattling, is this a factory thing or something someone added later? If it is a factory part what is the correct measurements becuase the front of the fender is bowed in to the frame like it is too short.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 12:41pm
OOPS!!  Unstyled...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 1:07pm
I don't have the measurements but I believe it's factory.
Wink
I am a Russian Bot
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 3:06pm
Yes, the tie bolts to the frame are factory.  The keep the fenders from vibrating, especially on the steel wheeled tractors.  I too dont have a measurement, most of em got taken off and pitched.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 4:43pm
Just pull your fender out until it is square with the frame and measure. Both ends are supposed to be threaded if you make one.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 8:51pm
They're  on mine. Mine is a 1937 Unstyled. I don't know if the earlier WC's or the styled WC's had them.
