Gleaner R series in wheat(small grains)
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner R series in wheat(small grains)
    Posted: 06 May 2022 at 11:46am
I know older conventional cylinder gleaner capabilities. But looking into possibly updating towards the R50/R52 Gleaner models. To those who have harvesting experience primarily in small grains(winter wheat, barley, rye, etc), how do these R models perform(threshing ability, clean grain sample,header size) in dry(13-14%)grain & wetter grain (16-20%)?? Wheat yields in the 70-90bu/acre. Any key factors to consider?
Thanks.
Edited by AC7060IL - 06 May 2022 at 11:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 11:58am
I'm no small grains guy, other than a very few oats. There's never been an issue with anything (that I know of) other than how chewed up the straw can be if you intend on baling it.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 12:58pm
I’ve heard a lot of people say the rotaries do great in all crops, but particularly wheat. There’s a few in the area around me still running R series and they all like them. We had S97s when I went on harvest, and they were wheat eating machines. Most of the grain was pretty dry but did occasionally hit a few higher moisture spots. They did great either way.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 6:15pm
I was running 3.5 to 4 mph with a 24 ft head in 90 to 100 bu wheat a couple years ago. Had .5 bu loss behind machine. I guess that's considered capacity. A 50 or 52 would need the narrow space rotor bars for sure to keep cylinder loss down or thats what I've been told. Rotary machine would just out eat a conventional any day. If you have a impeller instead of chopper then straw does come out fairly long but it does chew it up some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 9:06pm
last small grain i combined was oats and used an N5, it did an excellent job in the field, and it did chop up the straw good.
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 11:02pm
Have run an R75 in hard red spring wheat and barley and they do well in both.   Like all combines, when the grain is tough it is easier to put it out the back.  Some debate about the number of reverse bars on the rotor in wheat.  Fewer reverse bars=more throughput but potentially more loss.  I think two is likely optimal.    Never see a 52 size machine around here just the 62/72 ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2022 at 11:48am
The chewed up straw is better yet. Not wanting to bale any straw.
I’m guessing that rotor sizes (diameter/length) is the major change for both;
-Series (N, r, r0,r2,r5,..etc?
-Model sizes within a series?
I’ve also read about improvements over series per feeder housings, rotor, cage, accelerator rolls, shoe length, chopper,spreader, ...etc. (hyperized, P1,P3, etc) So any particular model or rotor/cage setup that’s better/best or one to avoid? I also read about sunnybrook, CDF, Bison, Precision Farm Parts, etc.
Edited by AC7060IL - 11 May 2022 at 11:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2022 at 7:46pm
Until you get into the Super "7" series (67/77) the rotors are all 25 inches in diameter and either 70 inches long (R-40-50-42-52-55) or 90 inches long (N-5-6-7/R-5-6-7/R-60-70/R-62-72/R-65-75/R-66-76).  You're talking R-50-52 series, so I will address those processors. These machines have what is called the P-3 processor which has short segmented cylinder bars about 18 inches long each in each of three stations. Normally I prefer the "wide-tooth" cylinder bar over the threshing area, which would be the right and center stations. If you are seriously going to do small grains, I don't think you'll be happy with the threshing of these crops with wide spaced teeth, which were really designed for corn/soybeans. You would desire a square-tooth 1 5/8" long chaffer for corn and soybeans and 1 1/8" short finger std chaffer for small grains. The helical bars inside the cage must be in good condition and when replacing them, chrome is worth the extra money as they last twice as long. Stay away from any websites that offer all kinds of "hyperizing" of a machine you haven't even used yet !!  Most of these parts are to go faster and faster and unless you aren't happy with the machines appetite as it is, stay away !! There are "reverse" flow cylinder bars on these combines and to start, you'll need two on the discharge end. To have zero reverse bars may cause to much rotor loss, so start with two and go from there. This is an actual adjustment to the processor to dial in what your desired results will be. R-50/52 is a nice small 6-row combine in corn that will do you 1,000 BPH when set right. Soybeans 6 or 8 rows depending on your terrain. The accelerator rolls must be in good condition and will wear the most on the right side under the concave area. I have replaced many one time on the right side only and then the next time both left and right sides.
Edited by DrAllis - 11 May 2022 at 7:52pm
This page was generated in 0.176 seconds.
