Proxibid -- worked well for me.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Proxibid -- worked well for me.
    Posted: 26 Apr 2022 at 9:09am
I wanted a B125 power unit. I put in a maximum bid amount b/c I couldn't get off work to attend the live auction and had to pay an online buyer premium and 2% internet user fees. However, I got the PU at nearly half of my max bid.
Proxibid's claim auctioneers don't see max bids before auction may be true:)
I am thrilled. The engine/rad are going in my ib. However, if you need PU parts/starter bellhousing/540rpm reduction pto, send me a pm. (Harrisburg, PA).
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 2:49pm
I’ve had good luck with them as well in the past.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 3:53pm
Does by chance the engine serial number start with CR?? Reason I ask is my CA has an engine in it that does start with CR and the only information I can find out about it is that most of the power unit serial numbers started with CR.In advance thank you
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 4:29pm
Yes. The PU engine serial # is "CR 49928 PA". The "C" is there - I should have cleaned off the crud better before taking photo.
I don't know what the "PA" after the serial # means, if anything.
Edited by KMAG - 26 Apr 2022 at 4:31pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 4:37pm
Many times, on various auction sites, I've gotten items for less than my maximum bid. I have faith in them. I am sure that if people started to getting the winning bid at the same figure as their maximum bid, then red flags would start to fly. Darrel
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 4:40pm
Congrats on your purchase!! Proxibid is the best, 'user friendly' online auction platform to use IMO as an auctioneer.
It is possible for auctioneers to be privy to max bids on Proxy, but they have strict rules governing the reason for Proxy to disclose them to the auctioneer. It must be a good reason why an auctioneer would need to know.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 4:50pm
Thank you, looks like my CA got repowered at some time,I sure do like that engine.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 8:44pm
If I remember right the PA denotes higher compression ratio for gasoline only operation (no distillate fuel). My WD and CA have it on the end of the engine serial number as well. I think the vast majority of engines were the higher compression ratio especially the later you got... Distillate became less and less popular over time vs. back in the 30s.
