allis chalmers 160 clutch pedal
flem1951 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers 160 clutch pedal
    Posted: 15 Apr 2022 at 8:54pm
greetings,
   the clutch pedal does not seem to be pushing down far enough to disengage the clutch. therefore, I cant put the tranny in gear. do i need to move the pedal on the enc of its shaft to increase the pressure on the shaft to disengage the clutch? I have removed all the play in the turnbuckle adjustment. anyone have any ideas on this?
thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 9:28pm
I have a 160, did this just happen or have you done a recent clutch replacement? Before I begin to chime in with suggestions give us some background info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 9:58pm
thx for the reply,
  its been sitting for a month as i tinkered with the general maintenance: oil and fluid changes, filter changes, ect. I did removed a set of shims from the clutch plates for the PTO because the PTO was  not disengaging. other than that not sure what would create the problem?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 6:33am
frist stage is the trans clutch ,so after adjusting the PTO n its releasing ,sounds like the trans clutch is sticking
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 6:46am
It worked OK fine BEFORE you changed anything....??
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 8:20am
yep worked fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 8:21am
how do i "unstick" it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 8:29am
I’d say when you removed a shim is where the problem is. I also had an issue with my clutch after a full rebuild. Totally my fault as my tractor was split for several months getting a complete engine rebuild and having both clutches rebuilt. Rick did an incredible job as usual on the clutches, but as I put the tractor back together I for which way the shims went back in. Also would not go in gear. So I split the tractor again. After trying to figure what was wrong, reading through 2 different manuals including the AC maintenance manual, there is no mention of how the shims are positioned. I finally figured it out as I laid the entire clutch assembly on the floor and used a flashlight to see what was going on. I had positioned the flat part of the shims inward which seamed correct, however I noticed that they were contacting the clutch edge at 2 locations. So I turned the shims with the rounded edge inward and that solved my problem. Make sure the flat edge is facing outwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 10:40am
You say you removed a set of shims? You should have only removed 1 shim from each of the 6 bolts. There should have been 3 shims per bolt unless there was a previous adjustment. Also make sure the shims are placed between the backing plate and clutch housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 5:20pm
Did you have a chance to look at the shims?
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 7:19pm
yep, pulled the plat and took a look. they are placed properly. my nest step is to try and pull it and see if the clutch is stuck.
thx for asking
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 7:47pm
Should be placed like this.
