NH Hay inverter |
Page 12> |
| Author | |||
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1594 |
Topic: NH Hay inverterPosted: 30 Mar 2022 at 7:58pm |
Does anyone on here own a New Holland 144 or 166 hay inverter and if so, do they work, and are they worth the money? They are expensive little things, but there are times when I just want to flip the windrow upside down and it's tough to do consistently with a rollabar hay rake. Is one model superior to the other one is another question. Thanks.
| Sponsored Links | |||
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 512 |
Posted: 30 Mar 2022 at 9:36pm |
I have a 166. It does a nice job of flipping or merging hay without roping, is gentler on the hay (saves more leaves), less greasing to do/moving parts, easier to turn left at field ends, unlike a rake. Ground speed isn't any faster than a rake, tends to bunch up in heavy first cutting alfalfa, rakes pick up driven on hay better. I don't know if one is better than the other, haven't used a 144.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 31 Mar 2022 at 7:07am |
I don't know what model but my family bought an old Ford New Holland a few years ago.
We really like it. It's great for those hard drying days when you can't get the bottom quite dry. Sometimes we run it slow in the afternoon 1-2 hours before bailing and it seems help. I like it because it always flips it, where sometimes a rake puts it right back how it was.
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Posted: 31 Mar 2022 at 7:48am |
I have a 144 and I like it. If you have that windrow that is damp or tough underneath that is the tool for you. By the time you get 10 acres inverted you can usually start baling. They have their limit in how big of a windrow it will take before blocking up. I have tried mine on straw and it will not work on a heavy straw windrow. Too fluffy and won't go through.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12326 |
Posted: 31 Mar 2022 at 9:57am |
We've got a 144, have used it for years and is a useful tool. It is a little......how should I say....."winky" in my opinion. And it will not handle a windrow at or above some magic thickness I don't know how to put a number on. I've been told a 166 is a little better made and more forgiving than a 144, but have never used one.
jvin248
Posted: 31 Mar 2022 at 11:59am |
. Not being familiar with the NH 144/166s I looked them up and ... that's a really complicated piece of equipment for rolling hay over. Even the NH 'rolabar' mentioned seems somehow clunky. The 'tedders' I see popular lately (primarily because they are inexpensive) look like they fling all the leaves off the hay. I haven't done any hay since I was a kid in the 1970s, but I don't remember any issues rolling over windrows to dry out with the antique (even then) windrow rakes we had. We had a pair that looked like the internet picture I found below, I remember 'Case' on the gear box in the front left corner as you look from sitting on the tractor or as it sits in this picture, but the 70s were a long time ago. We'd cut the hay with a WD+sicklebar mower (I had the job sharpening the cutters) then rake with a Ferguson TO35 and bale with the Oliver 880 plus MF or JD baler and hand stack bales on the wagons. Edited by jvin248 - 31 Mar 2022 at 12:00pm |
Tbone95
Posted: 31 Mar 2022 at 1:41pm |
jvin, not sure how a NH Rollabar looks clunky compared to the rake you show, it's pretty much the same thing. Ground driven gear box and teeth that rake up the hay.
Back in the early and mid 70's when I first remember raking hay, we had I think a JD rake that looked a lot like your picture. The rollabars are for one thing the angle of attack is a lot more "crossways" to the row, not so much angle like the old ones. And the weird thing, they seem to speed up every so often. You're going along, watch the bars rotate, all steady, then "zing" they're going faster for a few revs and it spits the hay out. If you try to flip it over 1/2 a revolution, it flings the hay out wide and flat. I've had better luck doing a 1 1/2 revolution, but it is very touchy. The inverters do an exact flop over very well.
AllisFreak MN
Posted: 31 Mar 2022 at 7:10pm |
Tbone95
Posted: 01 Apr 2022 at 7:24am |
Exactly! Ditto on the horse customers too. The rollabars do great raking up from the mower, but suck trying to do a flop over.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1062 |
Posted: 01 Apr 2022 at 12:00pm |
When I was raking with the ol' WC or D17 and a NH “rollabar” in the 60s, I kept busy dreaming of some kind of machine to flip the windrow 180; the rake didn’t do that great of job like others have said. Most of the time it was OK, but other times it would flip the windrow too far or not quite far enough. Always seemed to be fighting it.
Corners would often bunch up, too. Belts?, chains? Wasn’t smart enough to figure it out back then. |
Allis dave
Posted: 01 Apr 2022 at 2:38pm |
Same luck here! rakes are ok and if you always have plenty of drying days, its no issue, but if your down to the last day before it rains overnight, every little bit helps.
I've found that usually when the rake speed up or slow down, it's because the teeth are in the dirt, the u-joints have a lot of slop, or the bar bearings are worn.
Tbone95
Posted: 01 Apr 2022 at 2:49pm |
Meh.....ours has done it since brand new. Teeth in the dirt will cause it no doubt, but it will do it anyway.
AllisFreak MN
Posted: 01 Apr 2022 at 3:20pm |
Yup, if consecutive drying days are plentiful then rakes are the way to go. But as mentioned, it's that situation where you are on the final drying day, you know the rain is coming, the hay is juuust about good to go but it's just a little damp on the bottom. I have been bit by that bug a few times which is why I thought maybe an inverter would be the answer. I have never seen one in use around here but am curious on how effective they are.
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 01 Apr 2022 at 7:32pm |
Are the "Big Wheel Rakes" still as popular as they were in the '80's ?? The guys arond "here" ran primarily NH angle/rail rakes, a few true MF rakes and an eve lesser amount of JD rakes of that style. The guy I worked for was "talked into" a 5 wheel rake to replace his MF, he dreaded that he let the MF go after 1 field of raking with the Big Wheel
Edited by FREEDGUY - 01 Apr 2022 at 7:32pm |
AllisFreak MN
Posted: 01 Apr 2022 at 8:19pm |
The big wheels are popular around here for round balers. I make small squares for horse owners so the 5 bar New Holland #56 rolabar is what I use.
Tbone95
Posted: 02 Apr 2022 at 8:26am |
Allis Freak, I would recommend an inverter. It is a “winky” machine in some ways, at least the smaller one is. Dad always joked it was made by med students.
Around here my biggest battle is dew. The dew is so heavy, then it’s humid. The dew doesn’t come off sometimes until 1:00 or later, then falling again by 6:00. The bottom of the hay won’t get dry in that time. Flip it with the inverter and you can at least get a couple hours of baling in. On drier days you can just about follow it around the field. It does what you want to do, I can’t imagine making dry hay without it in my operation. |
DougG
Posted: 02 Apr 2022 at 8:35am |
Never heard of a hay inverter- its a neat machine !
Edited by DougG - 02 Apr 2022 at 1:05pm |
AllisFreak MN
Posted: 02 Apr 2022 at 12:43pm |
Tbone95
Posted: 02 Apr 2022 at 12:55pm |
All that sun and maybe the big belt is getting weathered? There’s really not much to them, so that would be my biggest concern.
FREEDGUY
Posted: 02 Apr 2022 at 6:11pm |
Seems "ODD" that there were TONS of hay put up in the '70's/'80's WITHOUT an "INVERTER"
AllisFreak MN
Posted: 02 Apr 2022 at 7:08pm |
There was also tons of hay that spoiled. Hay inverters are just another tool that was invented to help prevent it. If New Holland didn't see a place for such a machine they wouldn't have marketed one.
rw
Joined: 28 Oct 2009 Location: United States Points: 385 |
Posted: 02 Apr 2022 at 7:45pm |
Haymaking is gambling addiction disguised as a challenge. Getting the labor out and the productivity up and preserving as much feed value/quality as is there at the time hay is mowed is the objective. Almost every hay tool has a unique situational advantage. Inverters fit this as there are times they are just the exact right thing and other situations they will be the wrong thing. Nothing else will flip a windrow like an inverter. A parallel bar rake or wheel rake can flip windrows that are wet on bottom but an inverter will do it better. Justifying the purchase is in the eyes of the beholder. I don't own one but know people that rely on them for certain situations. One windrow at a time might limit productivity and therefore usefulness for some operations.
Seems "ODD" that there were TONS of hay put up in the '70's/'80's WITHOUT an "INVERTER" ![]() !! No telling the feed value lost from hay baled too wet and the man hours spent per ton. As a nation we tend to be able to keep enough feed made good enough and stored good enough for the herd no matter the year. Sometimes you don't know until you try new things. We got into round bale silage and the most striking thing is baling straight out of a windrow laid by a mower conditioner how few leaves are on the ground and how the crop and machinery are off the field letting the regrowth begin. The waste in storage is low and the cattle clean the racks with the least refusal. The cost of the wrapper and plastic is recovered easily and there is no barn needed for storage. To speed up the process I reluctantly bought a Krone 22 foot rotary side delivery rake. It cost more than I liked but the productivity in wet or dry hay put this operation in a much better position to recover the optimum value out of the standing crop. This rake puts four 11 foot mower passes into one windrow for my 5 x 6 baler. An unexpected benefit has been the that the dry baled hay seems to keep in the bale better with way less heat damage when compared to our former process using a v wheel rake. I loved the v wheel rake and it was right for us at the time but the rotary rake is better for keeping soil out of the hay or silage. The better dry down and less heat damage was a pleasant surprise. |
FREEDGUY
Posted: 02 Apr 2022 at 7:49pm |
It was just a "HERE" observation, I see your climate could be a different animal.
Tbone95
Posted: 03 Apr 2022 at 6:23am |
Yep, we struggled for those decades putting up tons of hay, saw this machine as a good new idea, tried it, and it was an improvement. Imagine that. |
Les Kerf
Posted: 03 Apr 2022 at 7:33am |
I put up tons of loose hay in my youth but I doubt that it will catch on with the big farms nowadays... ;-)
Tbone95
Posted: 03 Apr 2022 at 8:07am |
I would love to be done or nearly done with dry hay. It is SUCH a battle with the dew and humidity. We live close enough to the big water that the wind can shift mid afternoon and shut you right down. And the weather apps suck, I wasn’t alive in the 1800’s but I have a hunch forecast accuracy was about the same. I’ll NEVER forget two years ago, beautiful second cutting so close to ready to go. Sent my daughter out for an hour head start inverting. It was supposed to rain that coming night. But no rain for the next 4 hours, and 0, yes 0% chance of rain for the next hour. Hitched up baler and wagon drove to the field. Baled about 15 minutes and the rain blew in!!! Infuriating, would have been better to let it lay. Any luck in the next couple years, will be wrapping silage bales.
Kurzy
Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Posted: 03 Apr 2022 at 8:14am |
Howdy, How about Allis Chalmers hay rake in 1951? No number, just called side delivery rake. Has two raking speeds and reverse tedding speed! Just picked one up. This thing is iron. Any idea what these go for? Kurzy
Tbone95
Posted: 03 Apr 2022 at 8:37am |
IDK, what did you pay for it, then I’ll have a better idea!
FREEDGUY
Posted: 03 Apr 2022 at 5:13pm |
Sorry for your lack of hay management back then
!! Like I said, TONS put in the mow "WITHOUT" the machine ![]() ![]() |
Tbone95
Posted: 03 Apr 2022 at 8:24pm |
What’s your friggin’ problem? Yeah, we put up 15000 plus squares per year. That literally is TONS. A lot of it was excellent. And now it’s easier to get it dry with a handy machine. Do you know how to manage weather? You should be a zillionaire if you do. Asshole. |
Page 12> |
