7080 Hyd. Problem
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: 7080 Hyd. Problem
    Posted: 23 Mar 2022 at 3:59pm
Since I got my 7080, the steering and remotes haven’t worked right. This was about a year ago. It’s been in an ex-Agco shop since October, and I haven’t heard any updates. I’m just curious what people’s opinions are…the steering works, but it turns really hard and you must use both hands. There’s a lot of resistance. Running the engine over half throttle helps a bit. Jacking up the front end makes no difference, and all the mechanical linkage is free. When you shut the engine off and bump the steering wheel, it turns back and forth quickly for a second or two like there’s a bunch of pressure in the system.
The 3pt works, I never tried to pick anything up with it so I don’t know if it will lift a load. The remotes will extend/retract a cylinder, but it would not fold my folding disc, or even lift it off the ground. Engine RPM made no difference.
I changed both hydraulic filters and the fluid. Some Teflon tape bits came out stuck on the outside of one of the old filters. All the parts for the filters are there, including the plate with the spring.
Anyone out there with 7000 series experience have any ideas? This is just for conversation, like I said, the tractor is still in the shop, but no one knows what’s wrong.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 5:03pm
The flow divider is stuck, and is diverting oil from the steering system and sending oil to the brakes. The spool needs to be removed, and polished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 5:53pm
Connect a 3,000 psi gauge to the "tee" fitting on the side of the PTO valve. Pressure should be 400 to 600 psi engine running hydraulics at rest. Activate a remote lever and the gauge should hit 2400 to 2500 psi. If this is true the hydraulics should work fine if you have correct coupler tips on your implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 7:59pm
Is it a FWA or two wheel drive?                       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 8:50pm
It is 2wd.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 8:50pm
my 7080 does the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 9:05pm
Power steering issues and hydraulic lift issues are unrelated. Two separate systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 9:07pm
That's what I thought. Each gets its flow from a different pump, so I was wondering why both wouldn't be working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 9:13pm
Until you get that 3,000 psi gauge connected, you'll never know anything about the lift system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 9:19pm
I'll call the mechanic tomorrow and see what he's done, and I might suggest that. I hate to be one of "those guys" asking questions all the time and telling a mechanic how to do his job, but it's been in the shop over 5 months and no culprit has been found. I need to be getting ground worked, it will be cotton planting time in a month and a half, and I'm tractor-less.
Edited by CrestonM - 23 Mar 2022 at 9:20pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 5:38am
Creston, hope your new 7080 is up & running soon so that you can enjoy tillage with it this spring.
Here’s some past AC forum posts that discuss 7000 series steering - hydraulic problems.
https://www.allischalmers.com/forum/7040-steering-problem_topic99136.html
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 7:05am
If its been in the shop for 5 months and no problem has been found the guy obviously isnt going to fix it. He should have said its beyond my capacity and given it back.
Ask any question you want its your machine.
Edited by JPG AUSTRALIA - 24 Mar 2022 at 7:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 8:23am
Are you sure the screen is in left filter and has Agco filters?
Earlier post, I was thinking 8070.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 11:28am
Mack, that is correct. I put Agco filters in, and even pulled it back out to double check the screen was present.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 12:09pm
And the right hand filter had the spring/cover go in first ?? filter would be last. It cannot be backwards and function correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 12:26pm
Yes, that is correct. When I got the tractor, it didn’t have the plate with the spring. Ordered a new one from Agco.
A couple times, the steering would work fine. But just for a few seconds, then go back to requiring two hands. But very occasionally it would work and you could turn it with one finger.
Edited by CrestonM - 24 Mar 2022 at 12:55pm
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 12:55pm
I bought a 7030 used in 1979. I still have the tractor.
The steering would not turn when cold and would work some when warmed up.
In the back of the left filter housing is a metal strap that the filter pushes against to open the door that lets the hydraulic oil into the housing. That strap was bent back so the filter could not open the door far  enough to let enough oil into he filter so the pump could work. How or why it was bent i don't know. If I remember I pulled the filter housing off to get the strap straight. Been working perfect since.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 1:41pm
If that is the problem (and it could be) the operator should hear the pumps cavitating, because they are starving for oil. This would also have an effect on the main implement pump, but again the hydraulic system would be making noises.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 3:01pm
Been 5 months since I looked at it, so I can’t say if that was bent or not. I never heard any pump noise, at least nothing like I hear on a lot of Deere models. We had one at a dairy I used to work at that sounded like a hammer tapping every time you used a hydraulic function.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 6:59pm
That  "hammer tapping"phrase brought back memories of the D15 Embarrassed!! I hope all gets sorted out for you sooner-than-later Creston
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 7:34pm
My B makes a hammer tapping noise under heavy hydraulic load as well, but the hydraulics work smoothly and it’s 80 years old this year, so I haven’t thought much about it.
At this rate, the “sooner” time period has already passed, i’m just hoping to get it back before fall harvest…
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 8:45pm
I have also found strap bent and found one on backwards.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 1:47pm
I talked to the mechanic, says he’s waiting on parts for his hydraulic tester. I don’t know what kind of machine it is, but the parts are back ordered. That’s the latest update
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 2:29pm
It doesn't take a hydraulic tester (flow-rater) to remove the steering pump priority valve and make sure it isn't stuck in its bore. If it's stuck and removed and polished and the steering starts to work like it should, there's no need for a tester.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 6:26pm
I agree with you, Dr. What I should’ve done in the beginning was try to diagnose it myself by asking about it here. With a couple gauges and a day’s work I might could’ve fixed it. Especially if it is just a stuck priority valve. But it was at the overlapping time of wheat sowing and cotton harvest, and I just had more than I could handle at the time. So I took it to the dealer, thinking he could have it done a lot quicker than I could. I believe in five months, I could’ve fixed the hydraulics, air conditioner, cab blower, and a blown remote outlet hose behind the cab. Whenever I get it back, I will still have to fix all of that. Great.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 9:26pm
I don't personally recall ever using a flow rater on a 7000 series. Won't say that I haven't, just don't remember. Gauges will tell you most everything you need to know. Sure sounds like a flow restriction problem to the pumps, especially the left hand filter. You seem to have two problems with two separate circuits that the common factor is that left hand filter and getting oil through it. Always possible to have two separate pump problems, but somewhat doubtful. I should also add,be sure that the sight glasses are full. They can get a brown film on them and appear to be full of oil when they are not.
Edited by Lynn Marshall - 29 Mar 2022 at 8:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 10:35am
I tried calling him yesterday but got no answer. You make a very good point, Lynn, about two different pumps having problems and having the left hand filter in common.
I did change the fluid before I took it to the shop, and removed and cleaned the sight glasses while I was at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:15pm
I have an update…the mechanic called me, he hooked his flow rater up to the steering circuit, and once the oil got warmed up, it flowed about 5 gallons or something to that effect. However, when a load was applied to the steering wheel, it wouldn’t flow at all, and it built less than 1000 psi. What he’s thinking, and what makes sense to me, is since the left hand filter was missing the screen when I got it, it wasn’t opening that door in the filter housing, starving the pump of oil, and what oil did go through there wasn’t filtered. I don’t know how well the previous owner cleaned his remote hydraulic tips when he plugged them in, I don’t know how long he ran it without that screen on the filter, but the assumption now is the gear pump  is probably junk.  And he said he couldn’t test the piston pump until the gear pump was replaced. A rebuilt gear pump was quoted at $3000, and a new aftermarket pump was quoted at $5000. I’m not sure what to do next, I know if I put this much money into the tractor I probably won’t get that back out of it, I would have a total of about $10,000 in the tractor.  I’m not sure whether I should try to find a cheaper used pump to put in, because I understand the gamble with that as well. Taking suggestions at this point.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:36pm
Over the years, I have bought several from salvage yards fairly cheap and as-is. I always disassembled them to inspect and replaced the transmission pump shaft seal and put them into service. Sometimes took two pump assemblies to make one that was good enough to use. But remember, my labor is free. The newer the pump is, the more improvements it has in it. Several changes occurred from 1973 until the last 1981 models.
Edited by DrAllis - 30 Mar 2022 at 7:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:43pm
Would a pump out of a 7020 work in this 1975 7080? There is a somewhat rough 7020 coming up at auction on Saturday, but the hydraulics seem to function as they should. I thought I might buy the tractor, take the pumps out of it, and sell or part out the rest. It has nearly new near rubber on the back, which I don’t need, but that might could help me recoup some of my cost.
Edit: I’ll add that while the hydraulics in the 7020 do work, they make a whining noise that I’ve never heard in any other tractor. It gets louder as I turn the wheel.
Edited by CrestonM - 30 Mar 2022 at 9:26pm
