‘45 power steering oil
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: ‘45 power steering oil
    Posted: 20 Mar 2022 at 3:55am
So what kind of oil should I use in the power steering oil reservoir? My books do not say? Thanks Amigos! Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 9:34am
about anything works... Some use ATF, some use 10wt... some use Universal tractor fluid... You got the UTF in several other places.. I would stick with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 9:42am
So you think plain hydraulic fluid or do you mean hydrants. Thanks. Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 9:47am
We uses universal tractor fluid in our Backhoe... same thing we put in the hydraulics and transmission.  Hytrans / CAT TO2/ Allis 821 / etc. ........... im sure some guys use "red" automatic trans fluid (ATF).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 9:49am
If you decide to use Automotive Transmission fluid (RED)... I would stick with the OLD ATF type and not the new MERCON LV or others that have a lot of ADDATIVES in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 2:15pm
My 45 had red fluid. It got switched to 821 and seems fine. My end loader uses Dexron in trans (Allison)...I see where the rebuilders are recommending 15w40 oil in same trans....Who knows?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 4:33pm
40 years ago i worked for FiatAllis Construction Division.. Big Mines had dozens of tractors. All the engines used 15W40... There was a big push to get the transmissions verified on 15w40 to standardize on the oil.... We had a couple dozers running 15w40 in the hydraulics instead of 10 or 20 wt straight oil.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 5:03pm
Lots of trucks run 15-40 in the steering especially the construction guys (gravel haulers). With the big 445 -22.5 rubber on steers it makes the steering work pretty hard. I stuck to power steering fluid and had good luck with that over the years.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 9:04pm
My fluid is red in my WD45 so it's ATF or cool-aid.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
