Early D14 Steering shaft/wheel
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: Early D14 Steering shaft/wheel
    Posted: 13 Mar 2022 at 10:24am
Working on my 1958 D14 with the steering wheel that uses a pin through the shaft.  In spite of it being incorrect for the year, I would like to put one of the newer model steering wheels with the center diamond for the power steering emblem....maybe even in the later year white.      Splined shaft I think.... Anyone swapped out parts to do this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 10:42am
hmm wonder if it'd be 'easy' to just swap steering wheel AND upper shaft ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 11:54am
That's what I am wondering.....if the upper shaft to the swivel could "match up" or if the design change was deeper for the later models that used the newer wheel.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 1:28pm
Yes make sure u get #4 ,5,6 when u pull shafte from later tractor . Here is a parts unit I have .Just never got that far where I can pull the shaft.
Edited by Fred in Pa - 13 Mar 2022 at 1:29pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 1:54pm
I am patiently working on the pins for both the steering wheel and the upper shaft.  I read here the pins are tapered and/or swaged on the ends, so I am trying soaking and tapping (banging with drift) to see if I can get any directional movement.   Taper does not make sense but perhaps.   The early parts diagram show pins with no description or numbers and look sorta like split roll pins but I am betting they are solid AND rusted SOLID too.  Thanks Fred, that one looks like it is gonna stay forever...wow!
Edited by rasman57 - 13 Mar 2022 at 1:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 4:14pm
I believe that I have the steering shaft that was removed from a D14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 5:26pm
I was able to drill the pin holding the upper steering shaft to the first U joint below the shaft and it separated with a few taps and some juice.  The steering wheel pin is a different story after rusting in place for 64 years so I am happy to be able to lift the wheel and shaft out together.
The shaft measures .875 (7/8ths) and the pin hole is approximately 3/8th of an inch.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 7:38pm
Black steering wheels are available for later model D14s with the power steering emblem.  Please don't put a cream steering wheel on a D14!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 8:50pm
Good to know.....   It isn't a NAFTA violation I hope.   I just sorta like the steering wheel.  I promise I won't drive it to Ontario.
