rear tires on 210
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: rear tires on 210
    Posted: 11 Mar 2022 at 8:34pm
What do you guys think about trelleborg rear tires on a 210.
Either 520/85R38 or 540/65R38.Any one have any experience with them.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2022 at 9:59pm
A friend has one restored with 20.8 x 38 firestones  and it has a good road speed and it looks good. Are those equal to 18.4 and 20.8 or are they the big ones?
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 12:10am
FYI. If I still owned my tire shop and you drove the tractor into my shop, those tires, 520/85Rx38 would cost you $1711.34 each mounted on the tractor. That is no fluid pumping and he gets rid of the old ones. If he buys these, make sure he puts the proper new inner tube in them. If he can't get Trellorburg tubes, Michelin tubes would work. I hope someone has a sale price on the tires. I never mounted a pair of them. They came out after I sold the shop. I have talked to a lot of people who have sold them. They are the folks who told me about the inner tubes. My old supplier was out of the 540's. They won't post a price if they have no inventory.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 6:57am
My only concern is the middle number in those tire sizes. That's the aspect ratio of width to height. So the first tire size 520/85R38 has a sidewall height 85% of the tire's width and second tire size 540/65R38 has a sidewall height of 65% of the width. The width of the tires are 20.4 inches for the 520 and 21.2 inches for the 540. There should be a chart online somewhere you could find the sidewall heights to make sure they will be correct. What size tire are you replacing?
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 3:27pm
Finaly talked to the right person and we have figured out the 520/85 is to tall so going to use the 540/65 if I go with trelleborg.
Are these good tires out in the field,any one use them.Oh,replacing 20.8.38 b.f. goodrich tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 9:47am
Also looking at 650/65R38.Where could I find wheel clamps for open center wheels since it had power adjust rims for 18 38's and i went to pressed steel wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 6:42pm
Going with trelleborg 540/65R38 on the 210.
Alos wondering if any one might have a good front grill
for this tractor and a front wheel hub for a 210.
Yes i know they're many that will fit but I think the 210
has a big screw in cap.
