600 Forklift restoration
d restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d restorer Quote  Post ReplyReply Direct Link To This Post Topic: 600 Forklift restoration
    Posted: 26 Feb 2022 at 6:53pm
Hi all
I’m restoring a 600 Allis Chalmers forklift from ground up, I have found I need to replace some snap rings which is constant section rings, I have looked up and down the internet and can’t find the size I need. It seems Allis Chalmers made their own sizes. Does anybody know where to get these?
Edited by d restorer - 26 Feb 2022 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 7:04pm
I doubt ALLIS made snap rings....Something should be available... I would guess "SOME" generic hardware available in 1960 is not available today, but not much.
What is the size ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 7:25pm
something like this ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote d restorer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:22pm
Front axle shafts has a constant section retainer size = Shaft size 2.230  Groove diameter 2.108  and width 0.160    The big bull gears ride this splined shaft and when i removed my oil pans, there was no clip on the shaft and the gears kept hitting the oil pans and wore through.   I tried AmericanRing and Smalley along with my favorite, Mc Master-carr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:33pm
Rich, im not 100% familiar with the application, but sounds like your putting and EXTERNAL snap ring into the groove of a SHAFT.... A 2-1/4 inch snap ring is basically  2.116 , so just a few thousandths bigger  than your groove depth and 1/2 of the width...(.078) ... Would it  be possible to put TWO snap rings into each groove ???
You can also use two of the standard external rings that have the EYES with HOLES... basically the same size ID and width.
Edited by steve(ill) - 27 Feb 2022 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:56pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 6:17am
I just pulled a few final drives apart ,  Same as D15 n 14,
part # 222455
Edited by Fred in Pa - 28 Feb 2022 at 5:12pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d restorer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 7:48am
I managed to find some on Mc Master-Carr but still in need of the axle retainer which is a round ring. Other rings i needed i just went with a regular snap ring, i hope that will work.
Not a big difference from a Constant section ring.
Edited by d restorer - 05 Mar 2022 at 7:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 7:55am
I have a few of them circle rings tehy are inportant to have drum set in correct position
