Model B Starter Coils
cfciii03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Topic: Model B Starter Coils
    Posted: 26 Feb 2022 at 10:10am
Have a 1955 Model B. Starter not working. Found the starter coil leads have separated from the copper terminal. Is it possible to reconnect ? If so, how ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 2:01pm
did they break or did the starter get HOT and melt the solder ?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 5:55am
What are you calling the starter coil?  Original starter used a push rod and button switch similar to the  WD.  No coil anywhere.
AaronSEIA
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:27am
They can be re-soldered but you had best be really good at soldering Tongue It requires a lot of heat to get it up to soldering temp quickly and then get out before it melts things that you don't want to be melted Cry
As mentioned above, I would first want to know what caused them to become loose.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:53am
AaronSEIA
I assume he is talking about the field coils inside the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 10:36am
Yes - we are talking about the coils within the starter. The copper leads from the coils are supposed to be soldered to the copper terminal. For some reason (maybe a poor prior repair) the solder cracked and the leads are no longer attached. Can the leads simply be resoldered ? If so, what solder to use ?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 1:21pm
If the solder cracked, it's either because it wasn't properly soldered, or the terminal and lead relationship was stressed enough to fracture the soldering.
They CAN be soldered... a rosin-core solder, and a POWERFUL soldering rig.  A BIG soldering gun might do it... but a torch-type heated tip iron would be best.
The reason why it'll be so difficult, is because the copper terminal will pull the heat away FAST.  Thermal transfer coefficient of copper is very high, that's why it's a preferred heat-sink material.  This being the case, it will tend to pull heat away from the solder point.
A propane torch would work, too, but you'll be faced with melting the smaller wire away, too.  Get in there with lots of heat, get the terminal hot, get solder on it, heat the wire quick, put 'em together, flow it, and get out.
What you do NOT want to do, is get the copper so hot that your flame changes to green... when that happens, you're destroying the copper.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 9:24am
First thing I would do is talk to Steve at B&B Cusrom Circuits
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 9:48am
This is really good advice.
I recently rebuilt the dead 6 volt starter for my Model C by purchasing a 12 volt kit from Ebay, complete with armature, field coils, terminal, bushings, etc..
I had to solder those field core leads to the terminal using a torch; I have a pretty good grasp on soldering (avionics tech, biomed tech, general electronics tech, etc. since the mid 70's) and I achieved a good bond, but there isn't much room for error.
I have no clue as to the quality of the the kit but I seriously doubt it is as good as what Steve provides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 8:54am
Coming into this a bit late, but to be honest, I don't get involved with repairing field coils. Once a weak link, always a weak link on them. Don't ask how I know that. LOL!  Yeah, I tried to repair them numerous times in my early years of rebuilding, only with failure at the end. I always just install a new pair of fields and be done with it. Dave's last sentence pretty much say it all.......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:04am
You might try a 'silver' solder or a 'hard' solder.
CLEAN the wire and lug first, bright and shiny, 'tin' both, then solder them together.
I do have a 250W iron here, 1" chisel tip..takes 'forever' to heat up BUT it's great at repairing  'big heatsinky' things....
