WC Zenith Carb Float Level
W Speedy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote W Speedy Quote  Post ReplyReply Direct Link To This Post Topic: WC Zenith Carb Float Level
    Posted: 22 Feb 2022 at 7:23pm
After 18 months I finally got the W Speed Patrol to a point where I could start it.  Using an auxiliary 1 gallon fuel tank I added gas to the last system needing liquid. It immediately found the low point, the shop floor. After pulling the carb 4 times switching out various components I started looking a little closer at the float.
 This machine sat for quite some time and I believe the fuel separated and the water froze in the bowl deforming the float. I twisted one float back in-line so it wouldn’t hit the bowl walls. I did get it started but one pint lasted about 1-2 minutes. The top of the float is about 3/16” below the gasket. I’ve read and viewed a few videos and they recommend 5/8”.
Any recommendations are more than welcome.
Thanks
45’ CJ2A, 46’ CJ2A, 46’ CJ2A, 48 CJ3A, 4?’ Frazer, 40’ WC, 46’ W, 63’ D, 18’ 3039R
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 10:19pm
You are working with a compromised float. If it works as it now is, leave it alone.
This page was generated in 0.143 seconds.
