Allis Chalmers B Mower
Kyle Delong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kyle Delong Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B Mower
    Posted: 10 Feb 2022 at 5:03pm
Hi all, I was wondering if a woods 42 belly mower, or a Mott d9 flail mower. Would work with a 1939 Allis Chalmers B.
Any information would be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 5:57pm
Many people use 59 or even 72 inch belly mowers on the B... I actually have one of each on two different Bs... The 42 may be a little narrow compared to the wheel rear end width.  I have no experience with a flail mower on a B.
I did see a FLAIL on a Farmall CUB so YES, it will work on a B... but it was best at cutting the grass every week. Did not do a good job when the grass was 12 inches deep.
Edited by steve(ill) - 10 Feb 2022 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 6:01pm
Woods 59 mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kyle Delong Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 6:24pm
Ok. How would I hook up the flail?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 6:31pm
welcome to the forum. Is mower 3pt
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 7:34pm
If it is a 3 point, you will need to rig up a couple stationary arms off the drawbar to hold the mower just slightly off the ground...
If it is a belly mower, it sets offset to one side and the belt runs back to a set of idler pulleys and the belt goes up around the pto pulley..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 6:30am
About 30 years ago I made one of those cub flail mower into a pin hitch mower to work behind a CA. It kinda did an OK job, maybe it needed new sharp knives? I unloaded it at a consignment sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:48am
Kyle, do you have a photo of how your flail connects to your present tractor ?  Can compare to the back of a B to see how / what kind of modifications would need to be done.
This page was generated in 0.277 seconds.
