Bleed cock on AC6080 Fuel Pump |
Post Reply ![]() |
REM ![]() Bronze Level ![]() ![]() Joined: 25 Nov 2021 Location: USA Missouri Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Jan 2022 at 5:28pm |
Where is the bleed cock on the AC 6080 Injector pump?
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8269 |
As your looking at the pump theres a bolt- takes a 1/2 wrench loosen it up - 6080,s are a bear too bleed, takes time or a small electric inline fuel pump helps
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Huh? I usually get by just fine opening the bleeder on the fuel filter then crack a line or two at the injectors.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21482 |
The more fuel in the tank, the better. Loosen bleed wing nut on top of the filter base and wait for fuel to run out with no sign of air. Then, go down to the injection pump INLET TEE and loosen the plastic knurled nut on the top of the tee until you again have a steady stream of fuel and no air. Not usually needed to crack injector lines, but one or two is enough, UNLESS you are starting the engine for the first time after an injection pump overhaul, which you don't say.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5075 |
With the asking of vague questions, it makes me think it is a tractor that has been sitting and the op thinks it just needs bled, but likely the pump plungers are stuck from sitting. These usually aren't that hard to bleed out.
Good point Ed, tell us what's going on with the 6080 first!
I just bought the tractor a few months ago. It has been running fine but a couple weeks ago in the cold weather it just quit on me while haying cattle. I let it sit for a while and it started back up. I was able to drive it back to the house and then ran it on idle for about 15 minutes with no problems. I shut it off and it sat for about a week. It started right up about a week ago. I drove it about 10 yards and then it quit again. Could not restart it. My assumption was that it wasn't get fuel so I checked and there was fuel to the filter. Then I wanted to make sure there was no air between filter and pump. So that is where I am right now.
return circuit is pluging up due to the internal flex ring breaking apart. It will likely be due for a pump service soon. Clean the top return fitting out or knock the ball out to buy a little bit of time. It is only a temporary repair.
Remove the fuel tank shut off on the right side bottom of the tank and let some fuel run free. Clean the shut off valve while removed. If you don't do this FIRST, you will be chasing your tail.
Post Reply ![]() |
