Converting an 8070 to dual pto
Shivvets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shivvets Quote  Post ReplyReply Direct Link To This Post Topic: Converting an 8070 to dual pto
    Posted: 20 Jan 2022 at 10:48am
New here, I am sure this has been posted and answered 100 times...but
I just got an 8070 and wondering how difficult converting it to a dual 540/1000 pto would be and also a cost estimate?
Or is that something you wouldn't recommend?
Edited by Shivvets - 20 Jan 2022 at 10:49am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2022 at 11:06am
Correct, it's been asked and answered, but I've never been involved in any of them so I can't specifically help you.  You could try the search function on here, but it's a little. . . . .well, you can try.  Someone soon will answer I'm sure.
So, why am I replying?  First off, welcome to the forum!
Second, what will you be running at 540 with your tractor?  Because, you have to be careful, you will be capable of a LOT of torque that can break stuff not intended for that much HP.  If it's light duty stuff, OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shivvets Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2022 at 11:18am
New Idea round baler and maybe a discbine
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2022 at 1:20pm
Welcome to the forum!
The search function can be very useful, frustrating at times but useful. Try an advanced search. Choose 'any date' for starters. Takes some trial and error.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2022 at 2:11pm
I would think you'd be fine, as long as you don't try and set land speed records while operating.  Just because you HAVE the horsepower, doesn't mean you NEED to use it all!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2022 at 10:13am
A lot of times when I’m having issues with the forum search, I go to Google and search my question, followed by “Allis Forum” and that tends to work decent.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2022 at 8:07pm
I’m 99% sure Tornado8070 has done it.
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2022 at 8:27pm
Most discbines are 1000 rpm.  Biggest problem I had with my 8070 is that is large 1000 only.   Got an adapter to use it on a manure spreader with small 1000 and worked OK.  Just was tightening the set screws on the adapter every few loads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2022 at 8:41pm
If it’s as simple as shaft size get a different PTO shaft built up.  We got a large 1000 and a small one for out grain cart just depends what tractor is going on. Deere and Genesis run the large 7580 and 8000’s run small.
This page was generated in 0.941 seconds.
