8050 tranny trouble
Kent warburton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kent warburton Quote  Post ReplyReply Direct Link To This Post Topic: 8050 tranny trouble
    Posted: 08 Jan 2022 at 10:55pm
Looking at an 8050 power shift. Tractor off goes through all gears..tractor running only goes in 4 forward but only moves in 2 of them...thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 7:15am
Try your explanation again.  Engine off, the shift lever "clicks" into R-N-1-2-3-4-5-6  ?? Yes or no ??   Engine running and Park lever in LOW range what happens ??   You CANNOT have your foot on the clutch pedal one tiny bit, or you will never get the shift lever to click beyond 4th gear …..
KWarby2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWarby2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 8:19am
Yes you are correct in how my brother explained the issue   in high or low the tractor acts stuck like uts in gear and will die if you let clutch out in reverse and 1st and 2nd but would move in 3 and 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 8:23am
I'd have to get into my service book, but initially sounds like a stuck valve. It could be worse and much deeper inside, but I'd have to research. Your tractor?? or for sale ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWarby2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 8:32am
It is one I am looking to buy very nice machine runs beautiful good price but has this issue and I was for certain shift cables but now I'm not sure after messing with it   maybe valve body change out but my dad thinks it's inside   would just hate to buy then have a major tyranny issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWarby2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 11:14am
Also this is an 82 had the throttle on the dash which sticker and all is still there but on shifter console they moved the h/l and range shifter to the right and added the throttle on left right next to them on top   wish I could get pic on here   it's way neat. Was there an upgrade to do this.     Also I've been reading my 7000 series service manual and I'm gathering that it may be a stuck valve   any more input would be greatly appreciated thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWarby2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 5:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 5:40pm
That throttle is home made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWarby2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 6:06pm
I didn't get pic resized small enough but that's what we thought. Looks really good in person   much handier
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 6:47pm
