any spray rigs b or c specific
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: any spray rigs b or c specific
    Posted: 29 Dec 2021 at 10:18am
did they make a mounted sprayer for the b or c
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 10:36am
You mean like a cultivator?WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 12:14pm
yes like mounted spray tanks and boom , i would guess that it would be some type of mid mounted tanks and rear mounted boom  cant see that it could have much weight on the back or maybe some sort of wd setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 12:42pm
Sorry Hud, I guess I took my smartass pills this morning.
24-D was released to the market in 1945-46.  Spraying wasn't very widespread in those days I don't think.
I'm no valuable help whatsoever, so I will crawl back under my rock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 1:39pm
I think Tbone has a valid point. If you ask about a sprayer back then,they said 'What's that"?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 4:52pm
we had some ground rented to hunt on and there was a converted CA on shop converted wide front and chain driven rear with tank under belly but CA above.
I have seen WD with similar modification w/o tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 7:30pm
The earliest sprayers were used in orchards, then Tobacco and vegetable farming.  Some of the old ones were pull behind with a wooden tank, but these were specialty equipment produced by independent manufacturers.  AC's first sprayers in the '60's for the D series tractors, some side mounted, some pull behind.  Sprayers really took off with the advent of no-till, back in the '70's...Wink
This page was generated in 0.079 seconds.
